Hope Mono Rear hub modification
Sponge
Hey, this is aimed more at the older riders who would be familiar with this hub..
I've got a Hope Mono rear hub on the back of a 24". Is it possible to mod this hub to have more engagement points? Mainly to save money for now (Pro 2 in future) but really would like to see how far I can experiment with this hub whilst I'm using it.
I seem to remember a while back someone did something with the freehub body/springs/pawls of an XC rear hub (same internals as a Mono IIRC?) so it'd give twice the amount of EP, albeit with a long term gamble.
Anyone know how it's done? It's an old hub but a quality piece of old kit so I'm just seeing if it can be improved in any way. Willing to take risks. :)
For clarification:
Thanks!
springs and pawl are the same as the xc and bulb, but the bulb hubshell came with a 36 ep ratchet thing in it rather than the 21ep the mono has. there is a bulb in the fs for 15 notes, you could swap all the bits over and get the extra ep's :)
couldn't see how you could mod it other than machining the freehub body to a 6 pawl system, but you'd still be better doing that with a bulb hub shell on and getting 72 ep (Y)
Edited by trials hoe
Thanks for all the advice guys. I thought it might be possible transplanting pieces from other Hope hubs but guess I was wrong! No worries, the Mono's a classic and the 21ep should be more than enough to have a blast on 24" for now. Just need to settle with a sensible ratio next!
From what I can remember the bulb hubs felt alot nicer, I wod buy that one if it's £15
You will get the ££ back by selling your mono.
