Kieran Morrison Posted January 25, 2013 Report Share Posted January 25, 2013 Hi all, I bought new cranks and fitted them tonight, but they dont go onto the bb fully. The spacers on the BB can move about 2mm each side and spin freely, so obviously the cranks aren't on properly. I've tightened them as much as i can but they dont seem to budge. Is this normal for new cranks? I've never had this problem before but maybe its the type of crank. They're Try-All cranks (the silver ones) on a Trialtech Sport Lite BB. Thanks Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted January 25, 2013 Report Share Posted January 25, 2013 Yeah, this is normal cause the splines on the cranks havnt worn as much as 2nd hand cranks. They will pull on further as you ride them, so for the first few rides, make sure the crak bolts are tight 1 Quote Link to comment Share on other sites More sharing options...
williams Posted January 25, 2013 Report Share Posted January 25, 2013 Think the Try-all ones are pretty tight from the start, and they have to be ridden in and re tightened often at the start. Don't count me as a trustworthy source though:) Mine where like that. 1 Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted January 25, 2013 Author Report Share Posted January 25, 2013 Yeah, this is normal cause the splines on the cranks havnt worn as much as 2nd hand cranks. They will pull on further as you ride them, so for the first few rides, make sure the crak bolts are tight Thought this might be the problem, but it never happened with my last cranks (trialtech sports) which were new aswell, but that might be because the BB was also new. Thanks for the help Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted January 25, 2013 Report Share Posted January 25, 2013 Thought this might be the problem, but it never happened with my last cranks (trialtech sports) which were new aswell, but that might be because the BB was also new. Thanks for the help The tolerances can differ from crank to crank, but ive found even with second hand cranks, they can take a while to 'bed' into the bottom bracket splines, so remember to bring a 8mm allen key with you, and just check them every half an hour or so on your first few rides. Quote Link to comment Share on other sites More sharing options...
bing Posted January 25, 2013 Report Share Posted January 25, 2013 get a rubber, or a shot filled dead blow hammer, and give them a good crack onto your bb, then loctite the bolts in for safety. should have very little problems, worked for me with new trialtech cranks and a tryall bb Quote Link to comment Share on other sites More sharing options...
Jake. Posted January 25, 2013 Report Share Posted January 25, 2013 Always happened with my old echo 24 bb, same with my mates echo 24. His came loose. Bings tip sounds spot on though, give that a go. Quote Link to comment Share on other sites More sharing options...
dave33 Posted January 25, 2013 Report Share Posted January 25, 2013 (edited) You should just use a torque wrench and do them up with that about 42Nm should be ok if I remember rightly. Basically just dont do them up like a mad man which is going to stretch the traper on the crank. Just keep checking them for a couple of rides. Once the alloy crank work Hardens it will stay tight You dont need the spacers on the bb Edited January 25, 2013 by dave33 Quote Link to comment Share on other sites More sharing options...
Jake. Posted January 25, 2013 Report Share Posted January 25, 2013 You dont need the spacers on the bb I'm pretty sure it clamps the echo press fit bb in place? If you don't have something clamping it, it'll loosen over time... I'm sure. Quote Link to comment Share on other sites More sharing options...
dave33 Posted January 25, 2013 Report Share Posted January 25, 2013 (edited) I'm pretty sure it clamps the echo press fit bb in place? If you don't have something clamping it, it'll loosen over time... I'm sure. Yea sorry I was talking about the trialtech bb's and cartridge style in general Edited January 25, 2013 by dave33 Quote Link to comment Share on other sites More sharing options...
Jake. Posted January 25, 2013 Report Share Posted January 25, 2013 Yea sorry I was talking about the trialtech bb's and cartridge style in general Ah yeah, the original poster is using a screw on bb. Got confused for a second. Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted January 26, 2013 Author Report Share Posted January 26, 2013 Just had a go on it and when i push down on the drive side pedal theres a squeeking noise, anyone know whats causing this? thanks Quote Link to comment Share on other sites More sharing options...
Azarathal Posted January 26, 2013 Report Share Posted January 26, 2013 Could be pedal bearings. Just a tiny bit of grease on the bb splines if it's an Isis bb, grease pedal + freewheel + bb cup threads Quote Link to comment Share on other sites More sharing options...
dave33 Posted January 26, 2013 Report Share Posted January 26, 2013 Just had a go on it and when i push down on the drive side pedal theres a squeeking noise, anyone know whats causing this? thanks Check the bb in tight in the frame. The trialtech has a shorter thread, iv found they come lose more often than others Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted January 26, 2013 Author Report Share Posted January 26, 2013 Went out after i posted this and the squeeking stopped for some reason Thanks anyway, will do all that if they start doing it again Quote Link to comment Share on other sites More sharing options...
