8 inch rotor for Avid bb7
Sam Song
if the caliper will clear a 200mm rotor there will good chance it will clear a 203mm one too. bearing in mind that a 203mm is 1.5mm bigger than a 200mm (by a radius measurement) so if it was to catch you could slap some washers between the caliper and adapter/mount to gain the extra bit if clearance is an issue (post mount caliper).
185... if you dont find that enough your pads are contaminated or Your dick is to small or Your ego may be lacking something... seriously I have never thought I needed more rotor size. Save some weight and fork stress...
Based on my ass being 95kg and running one on a stock No problem
Edited by ogre
