Blake Posted January 24, 2013 Report Share Posted January 24, 2013 (edited) Right, got Euan Beaden cutting down a hope pro 2 for my mod, everything's ready but we have one problem. Because of it being shorter we have to remove one of the bearings (or is it 2 of them?) either way, they're what compresses the driveshell into the hub, so when we take them out, what do we use to press it all together? Someone must know, dave33 will hopefully see this. Thanks George. Edited January 28, 2013 by DrStix Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted January 24, 2013 Report Share Posted January 24, 2013 If all fails I've got a gold one forsale so you can try again . 1 Quote Link to comment Share on other sites More sharing options...
trials hoe Posted January 24, 2013 Report Share Posted January 24, 2013 get a narrower bearing? or a shim? Quote Link to comment Share on other sites More sharing options...
Blake Posted January 24, 2013 Author Report Share Posted January 24, 2013 I'll send this thread to euan as it stops me being a middle man and losing any information. Quote Link to comment Share on other sites More sharing options...
dave33 Posted January 24, 2013 Report Share Posted January 24, 2013 If you want to send me the hub I will take a look Quote Link to comment Share on other sites More sharing options...
dezmtber Posted January 24, 2013 Report Share Posted January 24, 2013 The freehub has two small bearings under the pawls then on the outside it has a spacer (remove this) and a larger bearing. I am pretty sure you just machine the freehub so the outer bearing sits thurther into the body and rethread the shortened freehub body. If you need a exploded view of the hub go to hope tech web site. There is loads on the tech docs Quote Link to comment Share on other sites More sharing options...
trialsEuan Posted January 24, 2013 Report Share Posted January 24, 2013 I have come up with a solution that I think will work. We will see if I am right today when I put it together, fingers crossed it will work!! Quote Link to comment Share on other sites More sharing options...
Blake Posted January 24, 2013 Author Report Share Posted January 24, 2013 I have come up with a solution that I think will work. We will see if I am right today when I put it together, fingers crossed it will work!! Oh god You're buying me a profile if it cocks up 2 Quote Link to comment Share on other sites More sharing options...
Blake Posted January 24, 2013 Author Report Share Posted January 24, 2013 Euan sent me this, Guess it's a good thing? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted January 24, 2013 Report Share Posted January 24, 2013 Depends if there's enough bearings and room for a lockring Quote Link to comment Share on other sites More sharing options...
Blake Posted January 24, 2013 Author Report Share Posted January 24, 2013 Depends if there's enough bearings and room for a lockring I hope there is or someone's getting a beating 1 Quote Link to comment Share on other sites More sharing options...
Joshm1991 Posted January 24, 2013 Report Share Posted January 24, 2013 I was gunna say.. What about a lockring? What gearing are you running on the mod to warrant a rear freehub? Joosh Quote Link to comment Share on other sites More sharing options...
Blake Posted January 24, 2013 Author Report Share Posted January 24, 2013 18:12 guessing he's tapping the lockring thread now. . . Quote Link to comment Share on other sites More sharing options...
Joshm1991 Posted January 24, 2013 Report Share Posted January 24, 2013 Ahh right! I can't wait to see this finished! I've seen it done once but it was a long time ago and I only saw one picture of it! Might be worth asking if anyone has the picture still Joosh 1 Quote Link to comment Share on other sites More sharing options...
Blake Posted January 24, 2013 Author Report Share Posted January 24, 2013 Ahh right! I can't wait to see this finished! I've seen it done once but it was a long time ago and I only saw one picture of it! Might be worth asking if anyone has the picture still Joosh Yeah i've seen pictures of swindlehurst's one, just hope euan figures out how to make this work 110% Quote Link to comment Share on other sites More sharing options...
Joshm1991 Posted January 24, 2013 Report Share Posted January 24, 2013 That's probably the one I'm thinking of then! Haven't seen it in ages! Even google can't help me! hahaa Joosh 1 Quote Link to comment Share on other sites More sharing options...
Blake Posted January 24, 2013 Author Report Share Posted January 24, 2013 Quote Link to comment Share on other sites More sharing options...
Joshm1991 Posted January 24, 2013 Report Share Posted January 24, 2013 Haha that's the one!! was his made by Hope themselves or did he make his like you're doing? Joosh Quote Link to comment Share on other sites More sharing options...
Blake Posted January 24, 2013 Author Report Share Posted January 24, 2013 His mate did it for him I believe Quote Link to comment Share on other sites More sharing options...
trialsEuan Posted January 24, 2013 Report Share Posted January 24, 2013 I've over come the bearing problem, and had to do a lot more to it to get it to compress when you do it up, whilst having room for the lockring. Cutting the thread now, and I've already tested it. - should work. 2 Quote Link to comment Share on other sites More sharing options...
williams Posted January 24, 2013 Report Share Posted January 24, 2013 If this works it's going to be awesome:) 1 Quote Link to comment Share on other sites More sharing options...
trialsEuan Posted January 24, 2013 Report Share Posted January 24, 2013 Right, this is the finished product. I've obviously done it differently to Danny, as I don't have a huge spacer next to it I am pretty confident it will work, and have clamped it up right to check and all seems well. Time to build the wheel and test it properly I guess. If anyone wants an exploded view of this I shall endeavour to do some pictures tomorrow. I've completely changed the inside of the freehub body. Quote Link to comment Share on other sites More sharing options...
isitafox Posted January 24, 2013 Report Share Posted January 24, 2013 Looks pretty tidy. I look forward to seeing the full wheelbuild and some footage of it in action. Cue the masses of PM's from people asking you to do one for them now! 2 Quote Link to comment Share on other sites More sharing options...
craigjames Posted January 24, 2013 Report Share Posted January 24, 2013 Looks awesome Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted January 24, 2013 Report Share Posted January 24, 2013 Looking forward to seeing this built up Quote Link to comment Share on other sites More sharing options...
