Magura hose advice
Dom_capper
Hi guys,
After cutting out a split in the hose which joins the two brake cylinders together, i'm having trouble getting the freshly cut hose onto the barbed fitting attached to the cylinder, has anyone got any tips?
Cheers
Dom
there are some special clamps that tartybikes sell in a magura bleed kit which makes things a whole lot easier http://www.tartybikes.co.uk/rim_brake_spares/magura_hose_clamping_blocks/c5p10026.html
you clamp the hose into these clamps in a vice and just tap the barbed fitting in
