slave cylinders help.
ashleys sugden
or take an old pad put it in the slave that works, place it in a vice (gentle) when you pull in the lever the piston (in the bad one) will come out all the way... spray the sh*t out of it.
Just a lot easier to pump the break instead of messing around with pliers, also you wont damage it this way (Y)
  • Like 1
Use a ziptie and do them one at a time? Easier than a vice
Put your finger on the good slave, hold it in while pumping the lever, the bad piston will be pushed out further, soak it.
fixed, for now, just need my crank bolts :P
just use disc brake cleaner or electrical contact cleaner then you can just drown the brake including the pads and rim without effecting the bite or brake brake surface.
http://compare.ebay.co.uk/like/320892803474?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&cbt=y
£3 a tin will clean your brakes 20-30 times
  • Like 1
But then iit can flush the crap from the cylinder to the breaking surface..
you´ll never sort it perfectly unless you´re going to get two slaves with the same spring ratio,wich even is impossible for magura employees obviously haha
you could warm the slave with a heat gun(from opposite to the piston!!!),while the pistons pulled out by something,to relax the spring of the good one,but thats only if theres no oil inside(taken apart)
Edited by FamilyBiker
