Kieran Morrison Posted December 30, 2012 Report Share Posted December 30, 2012 I ordered a rockman manus 2 the other day and I'm not sure if I should order a bashplate or not. If I was to use one, could it potentially crack the frame after some hard hits or does the style of bash plate mount it has stop that? I don't know if a bashring would be enough protection for that area of the frame, I'm left foot forward so if I failed something like a frenchie ( at an angle) would the bashring stop me from hitting the frame most of the time? Any disadvantages of running a plate opposed to a ring? (other than a bit more weight) Cheers for any help Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted December 30, 2012 Report Share Posted December 30, 2012 If you are worried about hitting the chain buy downtube protector, not a bashplate that will transfer all impacts to the frame Quote Link to comment Share on other sites More sharing options...
Jake. Posted December 30, 2012 Report Share Posted December 30, 2012 I run only a bashring, and have done for 2 years now... I'm left foot forward and it's fine, just use a bashring. Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted December 30, 2012 Author Report Share Posted December 30, 2012 I'll just stick with a bashring and a downtube protector then Cheers Quote Link to comment Share on other sites More sharing options...
Jake. Posted December 30, 2012 Report Share Posted December 30, 2012 If you want to get really anal about it, grind the bashplate mount off too. Just the sticky out bit. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted December 30, 2012 Report Share Posted December 30, 2012 I prefer the bashring to bash plate so much. Use a bashplate as a bigginer by all means but i know you're not so its time for a bashring Quote Link to comment Share on other sites More sharing options...
Blake Posted December 30, 2012 Report Share Posted December 30, 2012 if you fail something like a frenchie at an angle, you tend to just go to crank most of the time anyway. Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted December 30, 2012 Author Report Share Posted December 30, 2012 I've never ran a plate before, always had a bashring but thought it might be a better idea to use a plate with this frame since it's weaker than any I've had before. It's fine though, I'll stick with a ring, thanks for your help Quote Link to comment Share on other sites More sharing options...
315r Posted January 1, 2013 Report Share Posted January 1, 2013 Ring, bashplate in this frame is a bad idea. Quote Link to comment Share on other sites More sharing options...
