will echo produce a 24" frame with disc mounts on?
ashleys sugden
as it says in title, im fed up with faffing about with rim brakes, i always have problems with them and they dont last long, my front disc is amazing, and ive never had any problems with disc brakes, just wondering if anybody knows if they are producing a frame with disc mounts and rim brake mounts?
<blockquote class='ipsBlockquote'data-author="Azarathal" data-cid="2476062" data-time="1356792232"><p>
Welding a disc mount on an alu frame wont end well. Jake hicky did it on his maladie / manus (can't remember which) and it tore off iirc</p></blockquote>
It was a maladie and if jaf were to do it you could ask for it to be bolted on instead if welded. Could easily be done with 2 bolts through the frame or even better a mount that attaches with a bracket instead to go around the frame holding it on. Also get him to carbon wrap it and it will easily be strong enough for a disc as the carbon will divert all the stress away from the mount ect.
