ashleys sugden Posted December 27, 2012 Report Share Posted December 27, 2012 so yesterday, i stripped my thread while riding on my trial tech cranks with echo sl freewheel on, was a nasty crash i must add. anyway i wanted to go riding today with my mate so he lent me his try all cranks off his 26" for the day, but i've noticed that they don't close up to my echo spacers all the way? (it is a echo 24" 2011 frame with Spanish bb by the way) which means there is a slight wobble, i think the bearings are ready for replacing, but will the fly bikes bearings fit my echo frame? as i don't intend paying £70 just for an echo bb installation tool, will i be able to get them in with a hammer? light hits is it the try all cranks not big enough? but i have been offered some trialtech ones, will the problem be solved if i bought the fly bearings and the cranks? and possibly some small spacers? thanks guuys Quote Link to comment Share on other sites More sharing options...
trials hoe Posted December 27, 2012 Report Share Posted December 27, 2012 are they the try-all expert cranks? (40 quid ones on tarty) have them on my 24 and it was the same, had to do them up tight as foook to get them to grip echo spacers. just got a spanner to lengthen the leverage of the allen key and all has been good so far. Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted December 27, 2012 Author Report Share Posted December 27, 2012 are they the try-all expert cranks? (40 quid ones on tarty) have them on my 24 and it was the same, had to do them up tight as foook to get them to grip echo spacers. just got a spanner to lengthen the leverage of the allen key and all has been good so far. yeah they are mate, ill have a go, will the problem be solved with the trialtech cranks? Quote Link to comment Share on other sites More sharing options...
dezmtber Posted December 27, 2012 Report Share Posted December 27, 2012 Check the diameter of you axle if its the same as the I think 22mm fly cranks then so long as there mid not Spanish bb it could work? I would be easier to get the right bearing from tartys though Quote Link to comment Share on other sites More sharing options...
trials hoe Posted December 27, 2012 Report Share Posted December 27, 2012 (edited) it might just be the tryalls are made with minutely tighter tolerances and the splines are a tighter fit, i did try some tt cranks on it at firstt but the nds splines were wobbly so they didn't get used but i'm sure they went on easier than the tryalls. think the cranks are made from two different grades of alu too, don't know if that plays a part in difficulty of fitting them. Edited December 27, 2012 by trials hoe Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 27, 2012 Report Share Posted December 27, 2012 I ran tryall cranks (the £100 ones) on my pure with Spanish BB and they didn't butt upto the spacers either so I think it must just be the cranks having a tighter spline. Also, yes those bearings will fit fine. To fit them either knock them in with a hammer or make a press with some threaded rod like you would for a headset. Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted December 27, 2012 Report Share Posted December 27, 2012 They don't need to be all the way up to the spacer as Isis still has a slight taper. I also had the same problem with my echo and try all cranks (£100) although I found my 2012 tr cranks fitted on perfectly. Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted December 27, 2012 Author Report Share Posted December 27, 2012 Check the diameter of you axle if its the same as the I think 22mm fly cranks then so long as there mid not Spanish bb it could work? I would be easier to get the right bearing from tartys though yeah they are the ones off tarty dez it might just be the tryalls are made with minutely tighter tolerances and the splines are a tighter fit, i did try some tt cranks on it at firstt but the nds splines were wobbly so they didn't get used but i'm sure they went on easier than the tryalls. think the cranks are made from two different grades of alu too, don't know if that plays a part in difficulty of fitting them. yeah they were pretty tough pulling them off my mates bike with the crank puller! I ran tryall cranks (the £100 ones) on my pure with Spanish BB and they didn't butt upto the spacers either so I think it must just be the cranks having a tighter spline. Also, yes those bearings will fit fine. To fit them either knock them in with a hammer or make a press with some threaded rod like you would for a headset. will do dave, ordered them just along with them hope pro pads, should be here next week They don't need to be all the way up to the spacer as Isis still has a slight taper. I also had the same problem with my echo and try all cranks (£100) although I found my 2012 tr cranks fitted on perfectly. yeah my tr cranks did that came standard on my echo, the try all splines are stiffer like the other guy said, they were tought to pull off! thanks guys, it should be ok with new bearings and trialtech cranks then Quote Link to comment Share on other sites More sharing options...
williams Posted December 27, 2012 Report Share Posted December 27, 2012 (edited) I have the £40 try all cranks and you have to tighten them up pretty hard! Regarding that bearing, I don't think that it needs to be replaced, but if so yes that beaings from tarty do fit. Just make your own tool like this: Edited December 27, 2012 by williams Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted December 27, 2012 Author Report Share Posted December 27, 2012 I have the £40 try all cranks and you have to tighten them up pretty hard! Regarding that bearing, I don't think that it needs to be replaced, but if so yes that beaings from tarty do fit. Just make your own tool like this: [img=http://www.bingshui.org/wordpress/wp-content/uploads/2009/10/IMG_0841.jpg] Sweet dude cheers Quote Link to comment Share on other sites More sharing options...
