trialstrider24 Posted December 25, 2012 Report Share Posted December 25, 2012 Got a new bike for Christmas and what is the best way to bed in your disc brakes? Thanks Quote Link to comment Share on other sites More sharing options...
CalopS Posted December 25, 2012 Report Share Posted December 25, 2012 (edited) lots of water and a big hill. Pump the brake to avoid glazing over the pads. Edited December 25, 2012 by CalopS 1 Quote Link to comment Share on other sites More sharing options...
trialstrider24 Posted December 25, 2012 Author Report Share Posted December 25, 2012 Cheers mate Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 26, 2012 Report Share Posted December 26, 2012 Be aware though that echo discs take a bit longer than normal to bed in properly so don't be disheartened if they take a while! Quote Link to comment Share on other sites More sharing options...
robintrial Posted December 26, 2012 Report Share Posted December 26, 2012 would other brake pads work better? my pads were glassy so i removed that layer with some sand paper. then tryed to bed them in again but it just won't work like it should. Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 26, 2012 Report Share Posted December 26, 2012 Hope pads are apparently better but it's the disc that is the problem, I think it's harder than the Hope discs which makes it longer though not impossible to bed in and work well. Quote Link to comment Share on other sites More sharing options...
bing Posted December 26, 2012 Report Share Posted December 26, 2012 Take the disk off, clean and degrease it, then put a sheet of 600 grit sandpaper on a flat surface, and rub both sides in a circular motion. Just rub hard enough to put small scratches on the surface. This helps bedding in no end in y experience. I found the Clarkes organic pads off chain reaction are the best ones. It's the same pads as a hope mono trial brake. Think they are about £4 at the moment Quote Link to comment Share on other sites More sharing options...
trialstrider24 Posted December 28, 2012 Author Report Share Posted December 28, 2012 Thanks guys! Quote Link to comment Share on other sites More sharing options...
