Freewheel and Cranks
trials owns
Ah wont be running bashring, Just had a look at tarty and found these,
http://www.tartybikes.co.uk/crank_spares/trialtech_freewheel_spacer/c55p10962.html
Quess i will have too get one on order!
Aye did see that vid beforehand, Which is why i didn't think i needed a spacer :'(
Edited by trials owns
<blockquote class='ipsBlockquote'data-author="dngr2self" data-cid="2474593" data-time="1356298001"><p>
Don't you get a spacer with the cranks? I'm sure I did with mine.</p></blockquote>
That's if your not going to use a bashring, they mean a shim that sits between your bash and freewheel. As mentioned you shouldn't need one as I have the older urban and it has a shim built in as with most modern bashrings.
Edited by bike_dummie
He's not using a freewheel. I was answering the original question.
