Echo 24" 2013
Danzo1p
post-27155-0-04535200-1356301002_thumb.j
post-27155-0-93651300-1356301046_thumb.j
bike is as in the pictures no marks what so ever its the latest echo 24" out just bought from tarty two month back
Hi
I know you are not allowed to test the waters on the for sale so i will do it here.
spec:
Frame and Forks
- Frame: Echo Trial 2013
- Forks: Echo Urban, Disc Only
Wheels
- Front hub: Echo TR Disc
- Rear hub: Echo TR 116mm
- Front rim: Echo TR
- Rear rim: Echo TR
- Spokes: Plain Gauge
- Rim tape: Echo, white
- Inner tube (front): Echo Unboxed
- Inner tube (rear): Echo Unboxed
- Front tyre: Kenda Small Block 8, 24 x 1.95"
- Rear tyre: Kenda Kinetics
Brakes -
- Front brake: Echo TR Hydraulic Disc, 180mm
- Rear brake: Echo TR Hydraulic Rim Brake
- Rear brake clamps: Echo SL
- Pads: Tnn adms metal backing, tnn refills
Drivetrain
- Cranks: Echo TR, 170 ISIS
- Freewheel: Echo SL 108, 18t
- Chain: Echo, 3/32"
- Rear Sprocket: Echo TR 14T Screw On
- Pedals: Echo TR Caged, Orange
- Bottom bracket: Echo Urban ISIS, steel axle
- Bashring: Echo Urban, Orange
Steering
- Headset: Echo SL
- Stem: Echo TR, 125 x 25
- Grips: Echo Rubber, Black
- Handlebars: Echo TR
Geometry:
Wheelbase: 1050mm
Chainstay Length: 360mm
BB Rise: +75mm
Weight: Approx. 9.2kg
bike is still in new condition used about 10 hours slight buckle in the rear wheel but is getting sorted tomorrow.
What sort of price do you think i could get?
Thanks
Dan
Edited by Danzo1p
