ashleys sugden Posted December 19, 2012 Report Share Posted December 19, 2012 i snapped three spokes on the disc side of the wheel in near enough the same place, ill get some spokes tomorrow from my local bike shop but how do you go about straightening them properly? i have a spoke key and all that and a home made wheel truer, just need some tips. also how would you go about spoke nipples that are rounded off too? would should i do with them? thanks Quote Link to comment Share on other sites More sharing options...
Blake Posted December 19, 2012 Report Share Posted December 19, 2012 Hit it with a hammer 2 Quote Link to comment Share on other sites More sharing options...
tigriss Posted December 19, 2012 Report Share Posted December 19, 2012 if it can help, look at that video: http://www.rushway.fr/mecanique/devoiler-une-roue/ Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted December 19, 2012 Author Report Share Posted December 19, 2012 ok thanks mate Quote Link to comment Share on other sites More sharing options...
Blake Posted December 19, 2012 Report Share Posted December 19, 2012 The rounded nipples, there should be a screwdriver head if you take your rim tape off Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted December 19, 2012 Report Share Posted December 19, 2012 Pop the spokes in, at even tentions. Then just find the buckle and tighten the opposite side to the buckle, If the spoke already feels its under enough tension, loosen the side where the buckle is. Just have a play around untill its true. Bear in mind your using a disc so the rim doesn't need to be perfect. Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted December 20, 2012 Author Report Share Posted December 20, 2012 ok thanks, but in the couple of rounded spoke nipples, the thread has come all the way through the nipple and will not let me put a screw driver in it The rounded nipples, there should be a screwdriver head if you take your rim tape off Quote Link to comment Share on other sites More sharing options...
skunky_bifta Posted December 20, 2012 Report Share Posted December 20, 2012 Pair of pliers? Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted December 20, 2012 Report Share Posted December 20, 2012 Molegrips if you get stuck, but replace the nipples while you're at it. Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted December 20, 2012 Report Share Posted December 20, 2012 Your using a disk aye? If it goes through the forks thats true enough. Remeber having a go on Ross McArthers marino a wee while ago and the wheel wa almost touching both sides of the forks. Quote Link to comment Share on other sites More sharing options...
dezmtber Posted December 20, 2012 Report Share Posted December 20, 2012 I would let the tension off the whole wheel then replace all the broken nipples and start from the begining as if i had just laced the wheel up new Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted December 21, 2012 Author Report Share Posted December 21, 2012 i have got it perfect with 7 new spokes and 7 nipples, thanks everyone, its near enough true! Quote Link to comment Share on other sites More sharing options...
