liamfriar199 Posted December 12, 2012 Report Share Posted December 12, 2012 hey guys, just wondering what you think i should do...make this or buy a different one for aruond the same price? this is what i was thinking FRAME: because color 2012 FORKS: Monty 219 magura RIMS: trialtech sport drilled TYRES: maxxis creepy crawler on front and rear BRAKES: avid BB7 on front, Avid BB5 on rear CRANKS: trialtech sport STEM: Trialtech race BARS: trialtech sport riser OR Try-all rage just listing the main things on the bike, excluding sprocket , chain things little pieces like that, what you guys think? good build? or bad build? Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 12, 2012 Report Share Posted December 12, 2012 You'll struggle with a disc brake up front and rim brake forks Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted December 12, 2012 Report Share Posted December 12, 2012 Those forks are a no no. Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted December 12, 2012 Report Share Posted December 12, 2012 if you go custom,go for marino!he´ll weld you together any geo(even copies of existing ones) and forks,too. Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted December 12, 2012 Report Share Posted December 12, 2012 You have said you are getting a "Custom" bike, and yet that Because frame can be bought from Tarty I personally would go for dual Maguras over the dual cable brakes, but if you plan on upgrading to Hopes or similar then fair enough. Quote Link to comment Share on other sites More sharing options...
ogre Posted December 12, 2012 Report Share Posted December 12, 2012 factory full builds are just better, the stem/bars usually suite the frame. and they're usually fair value. unless you've been dabbling in trials long enough to just know what you want from a custom build you'll probably f**k it up or spend eternity changing shit.. seems how it is in my experience, every factory full build i've used has been better than the coble together builds you tend to find... although any combination of high bb high ep fw and isis/oversized and your winning... Quote Link to comment Share on other sites More sharing options...
Blake Posted December 12, 2012 Report Share Posted December 12, 2012 Why are you going for the cheaper brake on the back? And an expensive frame but shitty forks? Nono Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 12, 2012 Report Share Posted December 12, 2012 On a more helpful note than my previous comment, I wouldn't bother with the Monty forks, get the try all entry forks and run maguras front and rear. Wouldn't be a bad little bike with that setup. And Doc, I'd hardly call the Because expensive. Quote Link to comment Share on other sites More sharing options...
liamfriar199 Posted December 12, 2012 Author Report Share Posted December 12, 2012 frame isnt even that expensive, i am a complete noob, just chose some stuff and threw them together reallycheers isita, would like to give the discs a try as i have the magura hs33's on front and back and they have been nothing but a big problem Quote Link to comment Share on other sites More sharing options...
Blake Posted December 12, 2012 Report Share Posted December 12, 2012 frame isnt even that expensive, i am a complete noob, just chose some stuff and threw them together really cheers isita, would like to give the discs a try as i have the magura hs33's on front and back and they have been nothing but a big problem If you don't really know what you're doing I don't think you should be building a custom bike. 1 Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted December 12, 2012 Report Share Posted December 12, 2012 Why are you going for the cheaper brake on the back? And an expensive frame but shitty forks? Nono BB5 is at least as powerful as BB7 and is stiffer(quite important for cable operated rear brake). Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 12, 2012 Report Share Posted December 12, 2012 i have the magura hs33's on front and back and they have been nothing but a big problem In what way? Quote Link to comment Share on other sites More sharing options...
liamfriar199 Posted December 13, 2012 Author Report Share Posted December 13, 2012 well the first day i got them put on the bike by local bike store they where fine, but then they just started to break about a week afterwards, first both pads stopped moving, then one stopped moving, now they both move but barely even stop the bike unless your pull very very hard, thats why i was thinking of trying out a disc Quote Link to comment Share on other sites More sharing options...
315r Posted December 13, 2012 Report Share Posted December 13, 2012 If you don't really know what you're doing I don't think you should be building a custom bike. This. Fork is the worst and heavy ever. Frame is nice, Quote Link to comment Share on other sites More sharing options...
stunt man t Posted December 13, 2012 Report Share Posted December 13, 2012 (edited) well the first day i got them put on the bike by local bike store they where fine, but then they just started to break about a week afterwards, first both pads stopped moving, then one stopped moving, now they both move but barely even stop the bike unless your pull very very hard, thats why i was thinking of trying out a disc they must not have been bled properly top pro's use dual hs33's save some money and fix the problem Edited December 13, 2012 by stunt man t Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 13, 2012 Report Share Posted December 13, 2012 Yup, sounds like a poor bleed and probably not good pads. I don't wanna judge but generally bike shops aren't great when it comes to jobs involving trials bikes! Quote Link to comment Share on other sites More sharing options...
liamfriar199 Posted December 15, 2012 Author Report Share Posted December 15, 2012 thanks alot guys! Quote Link to comment Share on other sites More sharing options...
