Because Simple 2009
Jake.
Hi there, built this bike up partly from spares. I was just wondering what sort of price it may fetch as I'm not planning on using it, I've listed a spec and pictures below.
Frame and Forks
- Frame: Because Simple 2009 20"
- Forks: Koxx Forxxs, HS33 Only
Wheels
- Front hub: Echo TR Non-Disc, 32h
- Rear hub: Echo TR Non-Disc, 32h
- Chain tensioner: Echo TR Snail Cams
- Front rim: Echo TR, 32h
- Rear rim: Onza Diamond Single Wall, 32h
- Spokes: Plain Gauge
- Rim tape: TryAll
- Front tyre: Monty Eagle Claw
- Rear tyre: Maxxis Creepy Crawler
Brakes
- Front brake: Magura HS33 2004 - Custom TPA
- Rear brake: Magura HS33 2004 - Custom TPA
- Rear brake clamps: Magura 4-Bolt
- Front brake clamps: Magura 4-Bolt
- Rear brake pads: CNC Coustsinks
- Front brake pads: CNC Coustsinks
Drivetrain
- Cranks: TryAll ISIS 165mm
- Freewheel: Echo SL 108, 18t
- Chain: KMC Z610 3/32"
- Rear Sprocket: Trialtech 12T Screw On
- Pedals: Echo TR Platforms
- Bottom bracket: TryAll ISIS, 128mm
- Bashring: Adamant, Silver
Steering
- Headset: Cane Creek
- Stem: Trialtech Forged 165x35
- Grips: French ID
- Handlebars: Trialtech Sport Riser
Geometry:
Wheelbase: 1020mm
Chainstay Length: 350mm
BB Rise: +65mm
Head Angle: 72°
Weight: 8.6kg including pedals
  • Like 1
  • 2 weeks later...
