Danny00135 Posted March 31, 2013 Report Share Posted March 31, 2013 Get some cousts on there! Quote Link to comment Share on other sites More sharing options...
williams Posted March 31, 2013 Report Share Posted March 31, 2013 honestly, rockman blues are the best pads i've ever used and i will continue to use them. This! 1 Quote Link to comment Share on other sites More sharing options...
SamKidney Posted March 31, 2013 Author Report Share Posted March 31, 2013 DonĀ“t get your hopes up, they are hs yellows you know... :wink2: Wish I hadn't, they suck. Going to purchase some cousts soon and put the yellows on the front when my ADM's wear out. I have some rockpads somewhere but they weren't amazing for me last time I used them. Front brake is mega though. 2 Quote Link to comment Share on other sites More sharing options...
bing Posted March 31, 2013 Report Share Posted March 31, 2013 Wish I hadn't, they suck. Going to purchase some cousts soon and put the yellows on the front when my ADM's wear out. I have some rockpads somewhere but they weren't amazing for me last time I used them. Front brake is mega though. Ah well, you can't win em all. Worked ok for me, they are better with a cnc backing though, trust me. Have you given up on tnn then mate? Quote Link to comment Share on other sites More sharing options...
SamKidney Posted March 31, 2013 Author Report Share Posted March 31, 2013 Ah well, you can't win em all. Worked ok for me, they are better with a cnc backing though, trust me. Have you given up on tnn then mate? Aye I know mate, they're not horrific but they arent right for me. Floyds new CNC backed pads on the same rim and brake setup has done the same. Good at first, and deteriorated as they go on. Given up? I still think they're quality pads. The set I've got up front are insane, but they wont work well at all on my rear Hole rim. Re-building my TR rim at some point and going back to LGM's/ADM's. Quote Link to comment Share on other sites More sharing options...
bing Posted March 31, 2013 Report Share Posted March 31, 2013 Might be the tryall rim. I used an onza pro rim with mine, on a harsh grind, and they were boss. Dan cox thought they were epic. I used them on the same rim again in plastic backed flavour, and they were again boss. I haven't touched the grind either. I was using a two bolt booster as well Quote Link to comment Share on other sites More sharing options...
SamKidney Posted March 31, 2013 Author Report Share Posted March 31, 2013 Frames got an integrated booster, so its plenty stiff enough. May well be the rim. My adms were sweet on the Echo rim, but when I slapped them on this rim performance dropped rather alarmingly.... Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted March 31, 2013 Report Share Posted March 31, 2013 just got to let rock blues bed in, they take time sometimes. my cousts were amazing straight away, but wore out fast! Quote Link to comment Share on other sites More sharing options...
SamKidney Posted March 31, 2013 Author Report Share Posted March 31, 2013 If I can find them I'll try them. Found some new LGM refills the other night, and I know those and my TR rim are a killer combo. Quote Link to comment Share on other sites More sharing options...
williams Posted April 1, 2013 Report Share Posted April 1, 2013 The rockman blues plastic backed aren't that good. But the CNC ones beats every pad I've tried! Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted April 1, 2013 Report Share Posted April 1, 2013 Plastic backed cousts are the best I've ever used! The only problem is they loose a little too much hold on a dying grind... Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 1, 2013 Author Report Share Posted April 1, 2013 I loved my ADM's on the Echo rim, just worked. This try-all rim seems to be the failing factor. Im running some adm's on my front TR rim and they're insanely good. Quote Link to comment Share on other sites More sharing options...
thinkdougie Posted April 1, 2013 Report Share Posted April 1, 2013 Viz and try all use the same material rims? Mines good but after a week as you said Sam lose all bite and not much hold. So Annoying... Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 1, 2013 Author Report Share Posted April 1, 2013 Viz and try all use the same material rims? Mines good but after a week as you said Sam lose all bite and not much hold. So Annoying... Mod rim seems wank compared to my 24" viz rim. Viz rim held a grind for a good while, this just doesn't. Quote Link to comment Share on other sites More sharing options...
thinkdougie Posted April 1, 2013 Report Share Posted April 1, 2013 Mod rim seems wank compared to my 24" viz rim. Viz rim held a grind for a good while, this just doesn't. My 2013 viz rim holds grinds for a week.... Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 1, 2013 Author Report Share Posted April 1, 2013 My 2013 viz rim holds grinds for a week.... I had the older "original" 24" viz rim, the one with the Try-All/Rockman-esque hole pattern in them... Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 24, 2013 Author Report Share Posted April 24, 2013 Bit of a bump, but this is the start of things to come: Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 25, 2013 Author Report Share Posted April 25, 2013 1 Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted April 25, 2013 Report Share Posted April 25, 2013 When i saw the above picture, i thought of Dan Cox, it looks like his old Comp. 1 Quote Link to comment Share on other sites More sharing options...
ashleys sugden Posted April 26, 2013 Report Share Posted April 26, 2013 (edited) that really is looking well Sam! nice one! Edited April 26, 2013 by ashleys sugden Quote Link to comment Share on other sites More sharing options...
Sam Moss Posted April 28, 2013 Report Share Posted April 28, 2013 like it might have to build mine up if i can do it mega cheap, not losing my 24. and then you lost your 24 ahah :| Quote Link to comment Share on other sites More sharing options...
williams Posted April 28, 2013 Report Share Posted April 28, 2013 When i saw the above picture, i thought of Dan Cox, it looks like his old Comp. This haha And that bike is sickkkkk Quote Link to comment Share on other sites More sharing options...
