peggysue Posted December 7, 2012 Report Share Posted December 7, 2012 Anyone have any tips on keeping it tight ? Yesterday my trialtech forks came , along with new try all 3d stem and rock man sloping top cap . Knocked a new star fangled nut in fitted everything nicely and the steerer is cut to about 2mm from the top of the stem . Both stem steerer bolts are as tight and even as they will go without snapping or threading them . All seems perfect but after 5 mins the headset starts to develop play and can't figure out anything more to do . Anyone else had this problem and solved it ? The echo stem I just took off never came loose Cheers Quote Link to comment Share on other sites More sharing options...
Blake Posted December 7, 2012 Report Share Posted December 7, 2012 What headset is it? Quote Link to comment Share on other sites More sharing options...
peggysue Posted December 7, 2012 Author Report Share Posted December 7, 2012 Echo sl sealed internal . Headsets great , bearings good and cups are nice and tight Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted December 7, 2012 Report Share Posted December 7, 2012 Steerer hitting against top cap? Quote Link to comment Share on other sites More sharing options...
peggysue Posted December 7, 2012 Author Report Share Posted December 7, 2012 No I tried it by also adding a 2.5 mm and 5 mm spacer under the stem with the same results so still none the wiser Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted December 7, 2012 Report Share Posted December 7, 2012 Cool - try sanding the anodising off the top of the steerer, with an anodised stem and forks it can be pretty slippery. Quote Link to comment Share on other sites More sharing options...
peggysue Posted December 7, 2012 Author Report Share Posted December 7, 2012 Cool was thinking about the surfaces being a little slippery so ill give it a shot and post back Quote Link to comment Share on other sites More sharing options...
AkuskaUK Posted December 7, 2012 Report Share Posted December 7, 2012 I've had this issue too, it was the steerer being slippery! Quote Link to comment Share on other sites More sharing options...
