Seized (03 I Think) Hs33 Maggie
JonNicholson95
this might sound stupid but it actually works..
Modify a pump with a bleed hose at the end of it.. lots of tape and what not so no air leaks from it
Remove the grub screw from the lever body (when the brake is fully built and screw in the slave)
attach the bleed hose to it and pump the s**t out of it until it comes out.
It happened to my pre 05 lever and this was the only thing that worked..
