Lewis Gething Posted November 23, 2012 Report Share Posted November 23, 2012 Hello guys, So after taking all the bits off my old frame to replace them on my new one, I noticed something seemed wrong with my rear hub. The axle moves independently, so only one side moves when I turn it. Surely this isn't right? The axle is also binding a lot, so the wheel no longer runs smoothly I need to take the hub apart to find out exactly what's wrong with it, but can't seem to be able to remove the axle. I have tried giving it a heavy tap with a mallet, but to no avail. Can any of you maybe give me some pointers as far as removing the axle/bearings goes? Any help is greatly appreciated, as I am desperate to ride my new frame Thanks very much! Quote Link to comment Share on other sites More sharing options...
Blake Posted November 23, 2012 Report Share Posted November 23, 2012 (edited) what hub have you got? EDIT: I am a huge tit Edited November 23, 2012 by DrStix 4 Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted November 23, 2012 Report Share Posted November 23, 2012 On 11/23/2012 at 6:08 PM, DrStix said: what hub have you got? Try-All H116 Non-Disc Hub, read the title Quote Link to comment Share on other sites More sharing options...
Blake Posted November 23, 2012 Report Share Posted November 23, 2012 On 11/23/2012 at 6:09 PM, Martin Reynolds said: Try-All H116 Non-Disc Hub, read the title faq Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted November 23, 2012 Report Share Posted November 23, 2012 (edited) On 11/23/2012 at 6:09 PM, DrStix said: faq not a blind 'faq' though Anyway, to the OP. sounds like ur axle is snapped, if you can move one side independant to the other. The axle will come out, you just need to be brave andgive it an almighty hit. You say your using a mallet, do you mean a rubber one? rubber will absorb the shock, so you need to use a metal hammer. Edited November 23, 2012 by Martin Reynolds 2 Quote Link to comment Share on other sites More sharing options...
Blake Posted November 23, 2012 Report Share Posted November 23, 2012 On 11/23/2012 at 6:11 PM, Martin Reynolds said: not a blind 'faq' though Anyway, to the OP. sounds like ur axle is snapped, if you can move one side independant to the other. The axle will come out, you just need to be brave andgive it an almighty hit. You say your using a mallet, do you mean a rubber one? rubber will absorb the shock, so you need to use a metal hammer. Would you not have to pull it out if it's snapped? Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted November 23, 2012 Report Share Posted November 23, 2012 its generally easier to hit it through the other side, you just gotta make sure the two parts of the axle are agaist each other where they are broken to push it through. Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted November 23, 2012 Author Report Share Posted November 23, 2012 On 11/23/2012 at 6:11 PM, Martin Reynolds said: Anyway, to the OP. sounds like ur axle is snapped, if you can move one side independant to the other. The axle will come out, you just need to be brave andgive it an almighty hit. You say your using a mallet, do you mean a rubber one? rubber will absorb the shock, so you need to use a metal hammer. Thanks man, seems like a new axle is what I need. Just had a look on Tarty and they are out of stock, and judging by how long it takes K-124 stuff to reach them, I am gonna be unable to ride for a loonng while yet I used both a rubber mallet and hammer actually, but obviously didn't try hard enough when giving it a whack Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted November 23, 2012 Report Share Posted November 23, 2012 On 11/23/2012 at 6:23 PM, streetrials24 said: Thanks man, seems like a new axle is what I need. Just had a look on Tarty and they are out of stock, and judging by how long it takes K-124 stuff to reach them, I am gonna be unable to ride for a loonng while yet I used both a rubber mallet and hammer actually, but obviously didn't try hard enough when giving it a whack I had to brace mine against the floor, and use a hand held sledge to get it out. as long as you support the hub when you're hitting the axle you'll be fine. Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted November 23, 2012 Author Report Share Posted November 23, 2012 On 11/23/2012 at 6:25 PM, Martin Reynolds said: I had to brace mine against the floor, and use a hand held sledge to get it out. as long as you support the hub when you're hitting the axle you'll be fine. Okay, I'll try it again in the light tomorrow. Thanks again dude! Sorry for making such a waste of a topic, I just really wanna get it sorted Quote Link to comment Share on other sites More sharing options...
Blake Posted November 23, 2012 Report Share Posted November 23, 2012 Would another axle not fit? Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 23, 2012 Report Share Posted November 23, 2012 I'm sure Jaff could make you up an axle if Tarty are going to be a while, however they did just get a Koxx delivery, it's possible they got some but just haven't got them on the site yet. 1 Quote Link to comment Share on other sites More sharing options...
williams Posted November 23, 2012 Report Share Posted November 23, 2012 You sure no other axle fits? Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted November 23, 2012 Author Report Share Posted November 23, 2012 On 11/23/2012 at 7:17 PM, williams said: You sure no other axle fits? That was going to be my next question The Rockman axle appeared to be what I needed, but apparently it is not compatible with the Try-All hubs I have taken mine out just now: Quote Link to comment Share on other sites More sharing options...
CalRobbo341 Posted November 23, 2012 Report Share Posted November 23, 2012 Wowzers, to think you may have been riding on that! I'm sure you could get Josh to make you one up! Look forward to the full build Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted November 23, 2012 Report Share Posted November 23, 2012 On 11/23/2012 at 8:17 PM, streetrials24 said: That was going to be my next question The Rockman axle appeared to be what I needed, but apparently it is not compatible with the Try-All hubs I have taken mine out just now: I think that's broken Its a shame how they've made massive long flanges for the bearings to sit agaisnt, and a skinnny center section. You think if they machined more off before the flanges, they could make the center section thicker, so you'd have the same weight axle but stronger 1 Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted November 23, 2012 Author Report Share Posted November 23, 2012 This is what I was looking for, in stock too! http://www.trial-bikes.com/tryall-rear-axle-p-536628.html Quote Link to comment Share on other sites More sharing options...
N.Wood Posted November 23, 2012 Report Share Posted November 23, 2012 I guess a 135 axle is no good to you, I have about 3 lying around! Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted November 23, 2012 Author Report Share Posted November 23, 2012 Unfortunately not Nick. Thanks anyways Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted November 23, 2012 Report Share Posted November 23, 2012 Tried messaging Ben at trials addict as he doesn't have all his stock on his site so he may have one at it will be within the the UK which is a bonus. Quote Link to comment Share on other sites More sharing options...
Jake. Posted November 23, 2012 Report Share Posted November 23, 2012 Damn Lewis Quote Link to comment Share on other sites More sharing options...
Rob. Posted November 23, 2012 Report Share Posted November 23, 2012 On 11/23/2012 at 8:17 PM, streetrials24 said: That was going to be my next question The Rockman axle appeared to be what I needed, but apparently it is not compatible with the Try-All hubs I have taken mine out just now: same happened to my tryall disc hub when i threw it after roid rage, took the axle down to an engineering place and got them to make me one and it worked and was lighter Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted November 24, 2012 Author Report Share Posted November 24, 2012 Update: My dad went down to the local bike shop early this morning without me knowing, and found these: Problem temporarily solved! Quote Link to comment Share on other sites More sharing options...
