jake.p Posted November 23, 2012 Report Share Posted November 23, 2012 I currently ride a standard saracen 2.zero which has V brakes they arent that bad really but i just wondered peoples thoughts on grinding the rims? Quote Link to comment Share on other sites More sharing options...
isitafox Posted November 23, 2012 Report Share Posted November 23, 2012 With some decent pads and setup nicely it'll make the world of difference Quote Link to comment Share on other sites More sharing options...
jake.p Posted November 23, 2012 Author Report Share Posted November 23, 2012 What pads do you suggest? Quote Link to comment Share on other sites More sharing options...
isitafox Posted November 23, 2012 Report Share Posted November 23, 2012 Either some Heatsink yellows or if you can afford it some TNN ADV's Quote Link to comment Share on other sites More sharing options...
williams Posted November 23, 2012 Report Share Posted November 23, 2012 Heatsink yellows sucks! Get rockman blues or TNN ADV's:) And grinding your rim, makes day and night difference! Quote Link to comment Share on other sites More sharing options...
miketrials1995 Posted November 23, 2012 Report Share Posted November 23, 2012 onza ice pads are around £5 on most websites and they work really well on a light or dead grind and last ages even if you drag your brake Quote Link to comment Share on other sites More sharing options...
williams Posted November 23, 2012 Report Share Posted November 23, 2012 (edited) onza ice pads are around £5 on most websites and they work really well on a light or dead grind and last ages even if you drag your brake Why do you wan't to drag the brake? Edited November 23, 2012 by williams Quote Link to comment Share on other sites More sharing options...
liam n Posted November 25, 2012 Report Share Posted November 25, 2012 Grinding rims is usual practise for trials. I recommend using a diamond cutting disc and apply gentle pressure, try not to go backwards over bits you've just ground as it kind of rubs off the grind. There are heaps of brake pads out there, if they're set up well and on certain rims a lot can work brilliantly. I'd recommend Coust pads my prefered pad (ones with 10mm of pad, you can buy from www.trials-addict.com and straight from heatsink bikes.) also heat-sink yellows can be pretty good. Rockman blues can work well. and finally TNN ADMs pads which have very good reviews 1 Quote Link to comment Share on other sites More sharing options...
OnzaComp2010Craig Posted February 4, 2013 Report Share Posted February 4, 2013 Heat sinks are good with a grind! Quote Link to comment Share on other sites More sharing options...
butterztrials123 Posted February 13, 2013 Report Share Posted February 13, 2013 (edited) I'm afraid of damaging my Rim if i grind :$ Edited February 13, 2013 by butterztrials123 Quote Link to comment Share on other sites More sharing options...
Rejoinder Posted February 13, 2013 Report Share Posted February 13, 2013 It's easy to do, and safe for your rim. Just take it steady and it'll be fine If it was dangerous for you or your rim there wouldn't be so many people who do it. Quote Link to comment Share on other sites More sharing options...
dan rider g Posted February 13, 2013 Report Share Posted February 13, 2013 here you go bud http://www.tartybikes.co.uk/media/guides/maintenance_rim_grinding/m2.html Quote Link to comment Share on other sites More sharing options...
