Bike Light?
Blake
Right, basically i've got a mountain bike with slicks that I use for commuting, and I was cycling back from my girlfriends earlier and I realised, I could probably due with some lights on this bike to make it a true granny mobile.
I don't want bikehut ones as i've had them before and they just fall apart when you go off a curb.
I was looking at this on chainreaction but before I get I was wondering what everyones experiences were?
don't really want to spend over a tenner.
CHEERS :D
I love it how whenever someone asks for something, u suggest the opposite.
want a set of forks with long steer, and u suggest 160mm.
want a light under a tenner, you suggest a £60-80 one :P
You can buy steerer extensions and I was just giving him a suggestion to a very good light that's a reasonable price.
At least I don't make people want to delete their thread. ;)
  • Like 1
ahhh, shh u ;) we're trials riders, im sure we're genetically made to piss people off :P
on a more serious note, how did u use 20mm of stackers on forks that short? surely, even with an internal headset, 100mm headtube + 20mm stackers + stem clamp height is gunna be way more than 160mm?
Right... Sorry then, moving on.
George do you want lights so that you're seen by cars or lights so that you can see in the dark?
If you want to be seen you don't need to spend more than a fiver, and if you want to see well then expect to pay around £30 for a decent one x
Martin iirc I did use 20mm stem stacker, not 100% sure.
Edited by JMCD
At £10 I assume you're just looking for lights that will stop you getting hit by cars and also stop you getting in trouble with the five-o's?
I bought these: http://imagethumbnails.milo.com/007/766/775/trimmed/7766790_8078775_trimmed.jpg
They're £7 a pair from Asda for some reason I can't find them anywhere online in the UK but they sell them in the bike section in store)
They're surprisingly bright, cheap and tool-less so you can switch them easily between bikes. Handy for if you fancy a night ride on the trials bike.
  • Like 1
I bought these: http://imagethumbnai...775_trimmed.jpg
thanks sam :)
Those tiny rubbery wrap around LED lights are so shit it's unbelievable. I've nearly hit people with them on a few occasions, they're just not bright enough to be seen (particularly under the glare of headlights which completely drown them out). If you really can't bear to spend more than a tenner, just get some from Decathlon, I'm sure they do must some basic LED ones for cheap. But don't whine when you get run over.
If you actually want to be seen, get one of these for the rear http://www.chainreac...x?ModelID=56550
and then one of these for the front http://www.ebay.co.uk/itm/290778308356?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
£25 for the pair.
Those torches are insanely bright, probably good enough for off road (I've not tried though). Battery life is a couple of hours but they come with 2 batteries and a recharger so it's all good. As above, zip tie / gaffa tape to your helmet. I bought a helmet mount off ebay for a few quid but you don't really need it.
