Moving Maggie
HippY
Hey guys
I just installed a pair of hs11 and i got a problem. Onthe front i could use the clamps on the O ring, so they are staying at the required position. But at the back i could not do that, if i tried than i could not screw the bolt in, now they are moving and they are not giving enough brake power. What should i do?
The rear ones uses levers, what i use as washers for the booster. I cannot post picture, im on iPod:/
I do not use washers at the back now, because i could nOt, but they are not tight enough, they are moving
