CalRobbo341 Posted November 12, 2012 Report Share Posted November 12, 2012 Does it matter what rotor you have with a certain brake? I plan on getting - www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=67246 will try on ebay first and what not. Can anyone recommend a disc for that brake too? Is it worth ordering from crc? Seen lots of negative posts from them recently. Quote Link to comment Share on other sites More sharing options...
Jake. Posted November 12, 2012 Report Share Posted November 12, 2012 My Dad orders from them all the time they're sound, discs don't matter too much but most people tend to get the same branded disc as the brake they're using. I have a hope tech and a avid rotor and that works well. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted November 12, 2012 Report Share Posted November 12, 2012 you can use any disc with any brake, doesn't matter what size, pattern or anything like that. I've found the shimano deore disc to be the best i've tried though. Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 12, 2012 Report Share Posted November 12, 2012 well, that's not entirely true, in an ideal situation you should be using a rotor with a braking surface the same depth as the pad, plus some rivets on alloy armed rotors hit against some callipers. 1 Quote Link to comment Share on other sites More sharing options...
