Best Grinding Disc For Rims.
BradJohnson
So,
i'm fed up with my stupid cheap grinding discs giving me a gash grind on my rims.
I'm currently using some disc's i got from B&Q not sure of the brand but they came in a pack of 10 for £10
when i get half way around one side of my rim the disc's are dead!
Just wondering whats the best disc's to use in 115mm as i'm going to screw fix tomorrow morning to get some.
I was looking at the makita ones/dewalt ones.
Any thought's, opinions or past experiences would be great.
Thanks very much!
removing the alloy from the grinding disc is crucial TNN told me. and so did other posters.. the disc type doesn't make much difference, push hard into the grinder while you grind, move it quickly and always check you havent missed a big spot of sidewall...
I found that the diamond cutting discs would give a deep, harsh grind but the grind itself would be quite dull. I only tend to use one for the first grind of a new rim as it cuts through the anodising easier than a cutting disc.
Edited by Echo Lite 09
