BradJohnson Posted November 8, 2012 Report Share Posted November 8, 2012 So as the weathers getting a little on the chilly side i guess i better get the good old maggy bled with some anti-freeze. I bleed my brake in the sink with a water bleed how much anti-freeze should i add to around 4L of water. Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted November 8, 2012 Report Share Posted November 8, 2012 It should give you the ratio on the bottle . Quote Link to comment Share on other sites More sharing options...
Jake. Posted November 8, 2012 Report Share Posted November 8, 2012 I've always read online that it is around 50/50 and 25/75... Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted November 8, 2012 Report Share Posted November 8, 2012 i got raped for this question last year! Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted November 8, 2012 Author Report Share Posted November 8, 2012 Hmm 2L of anti-freeze is a hell of a lot Jake. I'll pop down stairs to to motor department while i'm working tomorrow and see what the bottle says Thanks for that Josh. Quote Link to comment Share on other sites More sharing options...
Blake Posted November 8, 2012 Report Share Posted November 8, 2012 if 2L is a lot use less water can't you use pure antifreeze? Quote Link to comment Share on other sites More sharing options...
Jake. Posted November 8, 2012 Report Share Posted November 8, 2012 Hmm 2L of anti-freeze is a hell of a lot Jake. I'll pop down stairs to to motor department while i'm working tomorrow and see what the bottle says Thanks for that Josh. Mix the two in a small bowl and use a syringe? if 2L is a lot use less water can't you use pure antifreeze? I heard antifreeze on its own ruins the brake? Quote Link to comment Share on other sites More sharing options...
Blake Posted November 8, 2012 Report Share Posted November 8, 2012 oh really? wondered if it did. . Quote Link to comment Share on other sites More sharing options...
trials owns Posted November 8, 2012 Report Share Posted November 8, 2012 Done my brakes a few days ago, I went down tesco's garage and bought some ready mixed anti-freeze, Only cost 3 quid. 1 Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted November 8, 2012 Author Report Share Posted November 8, 2012 I've always wondered what a pure GT85 bleed would do.... It's cant really eat the seals cause its an actual lube what coats everthing in PTFE (silicone) Unlike WD40 which is just a water disperser. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 9, 2012 Report Share Posted November 9, 2012 Anything from about 30% antifreeze and upwards about will be fine. You could always bleed with a syringe, then you don't need to fill a sink? WD40 bleed works alright, GT85 doesn't (tried both). 2 Quote Link to comment Share on other sites More sharing options...
Maxx Posted November 9, 2012 Report Share Posted November 9, 2012 Isn't antifreeze as fluid as water ? I personnally always use coolant liquid (those for cars), it's always worked great for me. Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted November 9, 2012 Report Share Posted November 9, 2012 I go 50/50 for antifreeze bleeds Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 9, 2012 Report Share Posted November 9, 2012 Isn't antifreeze as fluid as water ? I personnally always use coolant liquid (those for cars), it's always worked great for me. Pretty much. Yep, same thing. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted November 9, 2012 Author Report Share Posted November 9, 2012 I'll try and blag the syringes from work. Quote Link to comment Share on other sites More sharing options...
Maxx Posted November 9, 2012 Report Share Posted November 9, 2012 Pretty much. Yep, same thing. So what's the interest of doing 50/50 water-antifreeze bleed instead of 100% antifreeze ? Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted November 9, 2012 Report Share Posted November 9, 2012 Cheaper? Quote Link to comment Share on other sites More sharing options...
