Need Help With Hope Headset
Liamd-24
It's one of the older hope headsets you have.
Starting from the bottom
You will have the crown race. Metal part you press onto the fork. It should have an o ring on it.
Then the bearing. Then frame cup.
The top.first the frame cup. Then bearing, then the compression ring with the slit in it. And sitting ontop the top cap with seal o ring.
They included the Hope HedDoctor setup in that diagram which makes things look a lot more complicated than they are - parts 13-19 are pretty much totally irrelevant to your situation.
The cups and bearings are all in the right place in your headset now, you just need to get the crown race - the silver ring - onto your fork. Once that's on you can put your forks up through the head tube. Once they're in, it's just a case of putting the remaining upper race and seals on there. They can only really fit on there properly in one way so you should be able to get work it out once the bits are there in front of you (Y)
