I Need Help With Wheels :(
Liamd-24
Hey :)
Well basically just starting trials and I'm building up a bike with minimum money :(
Iv been looking for 2 cheap 26 wheels but can't find any cheap wheel sets
So I was just wondering if would a cheap Shimano? Hub would be okay? Then just get a rim and build it myself or do I need to get something amazing?
And also could I just buy mtb cranks and leave the 22t chainring on it?
And this may be a stupid question by what are the holes in rims for?
Thanks
Hey :)
Thanks
You could probably get away with a cheapish Shimano on the front for a while, the STX-RC hub I had years ago is still going strong!
Yes you could just buy MTB cranks but I wouldn't recommend unless you're gonna get a Hope Pro 2 rear hub which will be expensive. Will be far cheaper to pickup a 2nd hand set of trials cranks, FFW like a Tensile and a fixed rear hub. Let me have a scan of the For Sale section and see what's about.
How much have you got to spend??
Yea that's the frame
I think I'm just going to get cheap Shimano hubs for the moment because I don't want to spend loads and then find out I don't like it :/
Then if I do like it ill just upgrade :)
Plus most new frames are 116 spacing now aren't they?
I was hoping to get disk mount on the front
Thanks for the help
Nope, most frames are 135mm. As for cheap shimano hubs bare in mind I got front and rear sealed Onza disc hubs off here for £10 each.
really ? :o thats amazing i cant find anything like that
and really? i thought they here different
im not sure what to do because i dont want to spend loads of money at the begining to find out im not that into it :\
i could get 2 wheels for about £70 if i build them myslef
