Flangeless Hubs?
Blake
straight spokes have got to be an improvement, i imagine they will become the norm in premium cycles, not having a bend in the spoke can only make it stronger and easier to product, and lighter?
I had to true a wheel on a Giant that had straight pull spokes. Constantly spinning spokes = hassle...
Anyways, can't really say I've had that many problems with regular spokes. Good wheel build, good hub, good rim, good spokes = good times.
  • Like 1
i've never had any issues, and i'm usually in the mantra of if it ain't broken... but that doesn't mean that we shouldn't be wanting better things. never thought about the spoke twisting, i presumed the end would be flat/shaped or something. i bet it's easier to replace a broken spoke on a straigh pull wheel..
I guess so, I'm just usually skeptical of the 'latest and greatest' in the MTB and road worlds because it's usually a massive load of bullshit.
The spokes are just a flattened end, so on the one I was working there wasn't anything to really dig into the hub or anything. It meant that on the tighter ones they just span which was pretty frustrating.
Couldnt you 'key' the spokes? like have a 6 sided allen bit (like a spoke nipple) where the spoke went through the hub?
  • Like 1
You could, but straight pull spokes are expensive enough as it is without making them a lot more expensive to produce. The good thing about straight pull and conventional spokes is that they're pretty easy to make - if you check out this video you'll see what I mean:
If you had to introduce a step where they needed to press it into some sort of hex head it'd make it pretty tricky to produce like that. Even just having a little lip of some sort that matched up to the hub would be fine, but again that's still complicating things. Similarly, it seems like most people don't really have a problem with cheap, easily available regular spokes and hubs :P
