Oh No an updated (page 2), Deng Bandwagon!
trials hoe
so here it is! i'm almost satisfied with it just needs a few flash bits to finnish it off, some hose shortening will have to be done too but its together and thats what matters
spec -
frame - echo trial 2011 (135mm spacing)
forks - old skool urbans (stock 4 bolt mounts cut off)
headset - crank bros. sage fr
stem - onza rip? (160mm x 35* by my measurnig stick)
bars - rockman rock bars silver (13*up 9*back) with tt foams
front wheel - echo tr disc hub on neon 2012 singlewall rim (4 cross disc side 2 cross non disc side)
front tyre - schwalbe blackjack 2.1 (pleasantly suprised by this so far) with a generic tube
rear wheel - echo tr non disc on neon singlewall (3 cross both sides)
rear tyre - scwalbe space 2.35 with a nokian dh tube
cranks - try-all expert 175mm isis
ffw - echo 108
sprocket - echo tr 14t
bash - neon cnc half ring
peadls - echo tr cage
front brake - echo tr lever on old xt 4 pot with clacks organic pads (180mm rotor)
rear brake - echo tr with lgm's in tnn cnc backings on gu mounts
think thats it.....
more pics requests are cool too (Y)
and finally a big thanks to all those that contributed by selling me stuff :)
cheers and enjoy.
Edited by trials hoe
  • Like 2
Haha, knew you'd say that :)
Really nice bike though man, if I went 24" again, all I would change are the cranks and brakes and bars pretty much :D
defo bars need to go, cranks are a tad heavy so they'll have to be upgraded too. front disc is sick to say its on fresh pads, i'm not sold on the rear slaves may switch to some maggies.
nice stem ;)
bike looks sick
cheers dude :)
Looking good, what combo is that front brake made up of???
the lever i got from you and an xt 4pot, kick ass setup for sure. (Y)
Where did you get your matching rims? i like.
ben at trials addict, these where the last ones apparently. they were red too, rawed right our the box.
old xt 4-piston brake does work good with echo rim brake lever?
interesting...
got a julie with hs33 lever,works good,too
it works fantastic mate, i ran an old julie on an 04 maggie lever a while back wasn;t as good as the xt/tr setup
Nah it's an echo disc brake lever, I have the other half attached to a Shimano lever
its a win win situation for everyone :)
