How To Make A Front Fw Louder!
ginge
She most likely has a 30 or 60 click Tensile freewheel, the 60 click is a good freewheel with a decent sound and engagement points, but the are louder ones and ones with higher engagement points. Plus the freewheel could be old making it a little dead on the inside.
She most likely has a 30 or 60 click Tensile freewheel, the 60 click is a good freewheel with a decent sound and engagement points, but there are louder ones and ones with higher engagement points. Plus the freewheel could be old making it a little dead on the inside.
Explode?
She has got an 09 pro mate, it has a bit of sound but nothing like it should!
Do as above and flush it out with some GT85. Tensiles are built up with some quite thick grease which makes them quiet and more likely to skip on you so a good clean up should see it right.
I wouldn't worry about it exploding at all, one of the most durable FFW's you can get is a tensile. They stand up to some proper hammer, just ask Flipp who was using one with about 2 pawls left for ages!
i´m coming from the background of beeing a bicycle mechanic,where high pressure cleaners for bearings and wd40 in general are no-gos hahaha
edit:only sealed freewheels i know are whites.tell me if i´m wrong.
and:air is everywhere,except space.lol
Edited by FamilyBiker
  • Like 1
No-one said anything about pressure washers....
And yes, there is air in freewheels, just not not any airflow through them which would cause dust buildup.
