Tar
chris H
Sorry to be a pain lads, i know a lot don't like tar, but i swear by it on my front brake. Problem is, i have no idea where to source some. Does anybody have some i could buy off them for a little fee? Would be really appreciated :) Thanks
Go outside, find a road, find a point where they've joined two pieces of tarmac together (old and new stuff) with tar. Dig it up.
Let water run into the hole. In winter it'll get turned to ice. Ice will expand hole. Crack around the hole. Cause pothole. Cause damage to car suspension. Put up price of road tax.
Or: http://www.diy.com/n...noCookies=false
  • Like 2
The ice would expand into the empty space above it where the tar was dug from.
If this were true we wouldn't have rocks/boulders spitting in two due to freeze thaw weathering, (water enters crack, freezes, expands and forces apart the rock over time).
There is a spot in a Tesco's car park where I dug up a shit load of tar around 4 years ago when I used to use the stuff, and that's started to split apart.
Grind and a good set of pads is miles better than tar.
  • Like 1
my mate once met a feller that owned a roofing company and he got chatting to him and he said oh i'll just break some off for you, he had it in massive barrels or bags or something i can't remember. But he basically smashed a massive chunk off with a hammer and thats te stuff i used to use years ago....if you can find anyone like that they might be able to help :) Roof tar is the ideal stuff i would say, the stuff i got was really hard so it rubbed onto rims dead evenly and smoothly rather than in sticky clumps.
Adam.
Nah, those that think its good do. Any 'benifits' it may give are massively outweighed by its cons. It melts in the summer, its hard to apply pefectly evenly, it makes a mess of your pads, makes it looks like youve used your rim to wipe your arse with if its any other colour than black, and if it gets the slightest bit moist it turns into a black oily mess and your brakes go to shit. Pads can stick to the rim causing crashes and possibly injury. Theres no option of riding in the wet either.
A good grind and a decent set of pads is all anyone will ever need. Spend some time setting it up properly and enjoy a consistantly performing brake, the option to ride in the wet and not having to smear a dirty oil based substance on your wheels.
And we're the ones that need to give our heads a wobble. If tars all that good, why arent the likes of Gilles, Fontenoy or Carthy using it?
Tars wank. I realised it was before Id even got through my first year of riding. Ive enjoyed better brakes for 4 years now as a result.
  • Like 1
Imo its a finishing touch. Even the smallest amount gives The extra bite and hold. I remember I use to use coke on v-brakes it was shit hot! Besides just because comp riders do not use it doesn't mean everyone else does not have to its personal preference really. It's like Marmite really
Edited by Andeee
People who say tar is gash need to give there head a wobble lol.
By saying it gash we're referring to when it's relied on.. I used to only use tar and I hated it, constantly worried if it was going to rain, but it doesn't stop me from bringing it on a ride in-case my brake suddenly goes poop... a good set of pads and a decent grind and you get the perfect brake that works in all conditions.
And once you keep using tar I found that it simply stops working.. you end up with shit loads of tar and no hold.. messes with your pads..
Jesus Christ what's with all these antitar people! I was on a ride last night with a mate. He rides an echo 24, light grind, belaeys, and it had good bite and hold...
I suggest putting some tar on for the little extra oomph (Take note people who think tar is hard to apply evenly) he held the bike in the air, spins the wheel by turning the cranks then let's it freewheel at quite a high speed. I proceed to put tar on by holding it very gently against the rim on both sides for about 3 seconds (about 3 wheel revolutions)... We both cannot see any sign of tar applied to the rim, but the brake is 2x louder and holds as if the brake was a vice.
This method means that if it rains you won't have a rank as f**k rim, the pads won't get all dirty from tar (they get dirty anyway lol, tar alone doesn't cause dirty pads).
Tar is a good thing if you know how to use it. Besides how do you know the world champion riders don't use it? If you apply it like I do then you wouldn't even know I had tar unless I told you.
No, tar is awful black shit for roads and roofing. Applying it to your rim may make the brake 'better' in the short term on a dry day but its nothing compared to a well set up brake on a decent grind.
On natural its draw backs are more abvious as 'finer' brake control is needed and heaven forbid it should rain...
  • Like 1
