EnnBee Posted October 27, 2012 Report Share Posted October 27, 2012 Front wheel build help Rim is a atomz offset 32 hole Hub echo tr disc Spokes sent by tarty are 186 I'm struggling to build this wheel. Any help I need to know the cross paterns and so on. Cheers x Quote Link to comment Share on other sites More sharing options...
isitafox Posted October 27, 2012 Report Share Posted October 27, 2012 The Tarty invoice should say which cross pattern the spokes are for though they usually send out for 3x (from my experience) unless you ask for something different. Sounds a bit odd that you've only got one size of spokes though with it being a disc hub as one flange will be nearer the centre of the hub?? When you get the spokes sorted though just follow Mark's guide here, although it says for a 36h wheel build it'll work perfectly as I did my wheels on the Speedrace from it and they were 32h. Quote Link to comment Share on other sites More sharing options...
trials owns Posted October 27, 2012 Report Share Posted October 27, 2012 Heres a wicked guide, To build a wheel if unsure, http://www.trials-forum.co.uk/topic/80777-how-to-build-a-wheel/ Quote Link to comment Share on other sites More sharing options...
EnnBee Posted October 27, 2012 Author Report Share Posted October 27, 2012 I've built a few wheels but always 3 cross or radial and that never a mix.Also checked all the packaging and no paperwork about what to do ? Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted October 27, 2012 Report Share Posted October 27, 2012 (edited) e.r.d. of the rim and hole diameter of flanges,flange distance? edit:left 3,right 2 crossings. youre welcome :wink2: Edited October 27, 2012 by FamilyBiker Quote Link to comment Share on other sites More sharing options...
EnnBee Posted October 27, 2012 Author Report Share Posted October 27, 2012 Will try that lad cheers. Quote Link to comment Share on other sites More sharing options...
trials bros Posted October 27, 2012 Report Share Posted October 27, 2012 This wheel needs to b ready fOr in the morning. U better get ur finger out or little Reece will not be happy. You wouldn't like it when Reece is not happy. Reece put the piss DOWN. Cheers boys. Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted October 27, 2012 Report Share Posted October 27, 2012 w? t? f? dunno what kinda beef is going on with you guys but if he´s going to lace 3x left 2x right i am sure reece is gonna be happy... 1 Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted October 27, 2012 Report Share Posted October 27, 2012 The paperwork will be in there, otherwise we can't pick the spokes usually with the receipt or wrapped up in the spokes. 3x disc, 2x non disc sounds about right though. Quote Link to comment Share on other sites More sharing options...
EnnBee Posted October 27, 2012 Author Report Share Posted October 27, 2012 Done it but a few spokes are. Bit long ? Is this normal or have I ballsed it up Quote Link to comment Share on other sites More sharing options...
FamilyBiker Posted October 27, 2012 Report Share Posted October 27, 2012 this normally happens only when you set the second leading spokes one hole in the wrong direction either at the rim or at the hub flange. i mean the spokes the others will cross over,on one side theyre wrong obviously Quote Link to comment Share on other sites More sharing options...
EnnBee Posted October 27, 2012 Author Report Share Posted October 27, 2012 Ok cheers. I just ground ends of spokes. Wheel is straightOnly my 4th wheel build. I'm still learning. Done 3back wheels easy and a radial front. But this was a bit complex for me Quote Link to comment Share on other sites More sharing options...
trials bros Posted October 28, 2012 Report Share Posted October 28, 2012 All done and very happy,and more important little Reece is happy....Cheers big boy ur a star... Quote Link to comment Share on other sites More sharing options...
