New Frame Problems
ULtrialsguy
So guys I recently got fed up with my old frame, an onza t-rex, who wouldn't like. Anyway I saw a neon bow frame for sale on here and promptly bought it for a good deal I must say. Thank you Seabasss for that. So I then also had to get snail cams as my old one had a tensioner. This was fine as I knew I needed one.
Then when it arrived I realised that my old frame had an internal headset and the bow needs an external one so I had to buy a new headset and I bought a new stem at the same time to compensate for the different geometry.
Sooo today I finally got round to putting everything onto the frame and when putting on my expensive middleburn cranks I found that the crank hits off the frame on one side and barely clears it on the other side. This clearly isn't going to work. Also I just bought a new BB a few weeks ago when my old one snapped and the new axle is pretty much as wide as you can get. So am I going to have to get new cranks to make it work? I really don't want to because I've pretty much spent all my money on everything else.
Advice please.. :
They're not mine, just thinking in terms of you could grind the cranks, reduce resale value, then find it hasn't solved the problem.
Well you wouldn't do it unless you know it's fixed the problem.
And a lot of problems like this have come up since people started going high BB.
grind off that corner maybe?
I found that even on my born frame, with a stupidly stiff back end, my cranks wouldnt hit if you rode normally, but when i put the power down i could flex the back of the frame and hit the cylinder with the crank.
I expect he'd have the same issue considering they run that close.
I'd advise selling your burns and get new cranks. Burns are sought after, and to be honest you could be left with money in your pocket if you sell them and buy some cranks with more offset :)
  • Like 1
I have a trialtech BB with 127.5mm axle.
Also does anyone know if the middleburn cranks have changed at all in the last few years so I could check the offset as mine are fairly old.
I dont think they've changed at all. They were designed ages ago, so they dont have much offset compared to trials oriented cranks
