Rockman Axle
ashleys sugden
turns out i need a new axle for my rockman BUB rear hub. tartybikes specify two sizes, the 116mm and the 135mm. but when i measured mine up, it measures up at 130mm.. not really sure what to do as im told the rockman axles are different to others. can anyone help? quote this post so i get a notification when you have replied :P
Measure from the edge of the dropouts.
http://tartybikes.blogspot.co.uk/search?updated-min=2012-08-01T00:00:00%2B01:00&updated-max=2012-09-01T00:00:00%2B01:00&max-results=12
Although being Rockman it may be diffrent?
Mod, 24" or 26"?
If your axle measures at 130mm, then you need the 116 one.
116 is the OLN (space between the dropouts), the axle is then around 4mm longer per side to sit into the dropouts.
Axles for 135mm frames usually come in around 142mm in actual length.
