VAMPIRE V12 Posted October 24, 2012 Report Share Posted October 24, 2012 now then guys. I've got myself another stem to put on my stock but my forks are a bit short (when i got them they had been cut down) when i put the stem on the forks with out any spacers the stem clamps up to over the first bolt but half way up towards the second bolt. So my question is what is really safe? Has anyone else had this problem? or if they got away with running one bolt? Cheers guys Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted October 24, 2012 Report Share Posted October 24, 2012 (edited) Mines just like that, quite a problem, since it's only clamping using one bolt, it puts uneven stresses on the steerer clamp, so chances are at some point it'll crack in-between the bolts. only thing I could suggest it to get a stem with a sloping top cap :/ also depending on what headset you have, if it's an open bearing headset like an fsa pig then you could shed some space by buying a slimmer like an echo sl headset or something of the sort... might get the steerer to reach the second bolt. Edited October 24, 2012 by Danny00135 Quote Link to comment Share on other sites More sharing options...
VAMPIRE V12 Posted October 24, 2012 Author Report Share Posted October 24, 2012 I was thinking about shaveing some off the stem at the top and bottom to see if that would help, its an echo stem. and atm its a shi**y Cane creek headset. Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted October 24, 2012 Report Share Posted October 24, 2012 My last bike had it like that for year. And the one I'm using right now has been like that for a year. I havent seen any problems with it. Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted October 24, 2012 Report Share Posted October 24, 2012 (edited) I suppose it's a bit like like cracking your frame, on paper it's likely to happen, but wheather it does is a different story. I run mine like that and i've had no problems Edited October 24, 2012 by Danny00135 Quote Link to comment Share on other sites More sharing options...
VAMPIRE V12 Posted October 24, 2012 Author Report Share Posted October 24, 2012 I suppose it's a bit like like cracking your frame, the same stresses are put on it, but it's not that likely that it'll happen. I run mine like that and i've had no problems Ahh well ill give it a bash cheers man!! Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted October 24, 2012 Report Share Posted October 24, 2012 if you have to ask, its proaly not safe. In this case I wouldn't run it. Have you thought about contacting JAF Bikes about a steerer tube extention? 1 Quote Link to comment Share on other sites More sharing options...
SamKidney Posted October 24, 2012 Report Share Posted October 24, 2012 What forks you running? If it's something like try-all's your screwed really. If its something burlier like Trialtech's or Echo's you should be fine Quote Link to comment Share on other sites More sharing options...
VAMPIRE V12 Posted October 24, 2012 Author Report Share Posted October 24, 2012 Running echo urbans the old school ones with a echo mod stem, yes this is on a stock bike if you have to ask, its proaly not safe. In this case I wouldn't run it. Have you thought about contacting JAF Bikes about a steerer tube extention? Did not know jaf bikes done a steerer tube extensions ill have a look, thank you Quote Link to comment Share on other sites More sharing options...
isitafox Posted October 25, 2012 Report Share Posted October 25, 2012 Think it's around £25 for an extension but I'm not sure if that includes postage. That's for a screw in extension, think Josh can do a cheaper welded extension but you're best giving him a ring. Quote Link to comment Share on other sites More sharing options...
