Blake Posted October 19, 2012 Report Share Posted October 19, 2012 Howdy. Would like to know an alternative to the gusset double six sprocket as they're out of stock on the 15t ones at the moment, and would like to order it asap. Was looking at a trialtech but is the base thick enough to not dig into my Chris King driveshell? Or when the gusset sprockets come back into stock. Thanks! x Quote Link to comment Share on other sites More sharing options...
Pete.M Posted October 19, 2012 Report Share Posted October 19, 2012 Gusset Double Six's don't fit on Chris King hubs, as I found out to my disappointment a few days ago! They have that special shimano-only pattern with the non-uniform splines. Luckily the trialtechs do fit, I went for the wider Lite over the Sport. Wouldn't surprised if it still dug into the driveshell though! Quote Link to comment Share on other sites More sharing options...
Blake Posted October 19, 2012 Author Report Share Posted October 19, 2012 but the lite is wider than chris king sprockets, by 1mm so surely it's less likely to dig in? Quote Link to comment Share on other sites More sharing options...
Pete.M Posted October 19, 2012 Report Share Posted October 19, 2012 It's just that the driveshells seem a bit soft, but you can't do much better than 6mm wide so I'm hoping for the best. Quote Link to comment Share on other sites More sharing options...
Blake Posted October 19, 2012 Author Report Share Posted October 19, 2012 surely 6mm is plenty wide enough as the CK ones are only 5mm Quote Link to comment Share on other sites More sharing options...
dave33 Posted October 19, 2012 Report Share Posted October 19, 2012 They all dig in a small amount but won't cut all the way around like a single sprocket from a cassette would, only on the alloy drive shell will it cut through Quote Link to comment Share on other sites More sharing options...
Blake Posted October 19, 2012 Author Report Share Posted October 19, 2012 got a steel driveshell Quote Link to comment Share on other sites More sharing options...
dave33 Posted October 19, 2012 Report Share Posted October 19, 2012 You don't have much to worry about then, just getting it off Quote Link to comment Share on other sites More sharing options...
Blake Posted October 19, 2012 Author Report Share Posted October 19, 2012 getting what off? Quote Link to comment Share on other sites More sharing options...
Pete.M Posted October 19, 2012 Report Share Posted October 19, 2012 The sprockets can get a bit stuck on, partly due to them digging in and partly due to the taper of the driveshell, but I'm guessing you don't have a sprocket on it already? I'm not totally sure about the taper of the driveshell, but it definitely felt like mine had a taper. Quote Link to comment Share on other sites More sharing options...
Blake Posted October 19, 2012 Author Report Share Posted October 19, 2012 Mine currently has a 13t sprocket on it that I will be replacing for a 15t one. I am not concerned about getting off the current one, just wanted to know the appropriate sprocket for my hub Quote Link to comment Share on other sites More sharing options...
Sam Song Posted October 19, 2012 Report Share Posted October 19, 2012 Gusset Double Six's don't fit on Chris King hubs, as I found out to my disappointment a few days ago! They have that special shimano-only pattern with the non-uniform splines. Luckily the trialtechs do fit, I went for the wider Lite over the Sport. Wouldn't surprised if it still dug into the driveshell though! Gusset Double Six does fit on King hubs! I have it on my bike right now and it works awesomely Quote Link to comment Share on other sites More sharing options...
Pete.M Posted October 19, 2012 Report Share Posted October 19, 2012 Strange! There must be some variance with one of the components.... Quote Link to comment Share on other sites More sharing options...
trials hoe Posted October 19, 2012 Report Share Posted October 19, 2012 did you try turning it round? sounds stupid but i did that with mine on my pro 2 ...... i was ashamed of myself when i realised what was going on 2 Quote Link to comment Share on other sites More sharing options...
Blake Posted October 19, 2012 Author Report Share Posted October 19, 2012 thought so, as tarty said they did. 1 Quote Link to comment Share on other sites More sharing options...
Pete.M Posted October 19, 2012 Report Share Posted October 19, 2012 (edited) did you try turning it round? sounds stupid but i did that with mine on my pro 2 ...... i was ashamed of myself when i realised what was going on Ha yeah I did try that. I think Chris King only make certain hubs with that non-uniform shimano pattern. Can anyone confirm this? Edit: My hub has a totally uniform pattern, but the Gusset double six I got from crc didn't. Edited October 19, 2012 by Pete.M Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 19, 2012 Report Share Posted October 19, 2012 Another +1 for a Double Six on a King hub. I had that set up, and a Trialtech Sport too. Both worked well. The Sport didn't seem to dig in on mine at all (definitely not compared to the 1-ER that had been on there before. Knife through butter). Quote Link to comment Share on other sites More sharing options...
Blake Posted October 19, 2012 Author Report Share Posted October 19, 2012 Another +1 for a Double Six on a King hub. I had that set up, and a Trialtech Sport too. Both worked well. The Sport didn't seem to dig in on mine at all (definitely not compared to the 1-ER that had been on there before. Knife through butter). Do you know when the gussets are going to be back in stock? I realised that after I asked a question on your site that they're out of stock, annoying! Quote Link to comment Share on other sites More sharing options...
trials hoe Posted October 19, 2012 Report Share Posted October 19, 2012 Do you know when the gussets are going to be back in stock? I realised that after I asked a question on your site that they're out of stock, annoying! or crc..... Quote Link to comment Share on other sites More sharing options...
Blake Posted October 19, 2012 Author Report Share Posted October 19, 2012 or crc..... Didn't think of that, need to get some magura washers and I do generally prefer getting stuff from tarty. Nicer to know if something goes wrong i'm not screwed. Quote Link to comment Share on other sites More sharing options...
trials hoe Posted October 19, 2012 Report Share Posted October 19, 2012 oooh you loyal bugger never had any probs with crc myself. hows the stem? Quote Link to comment Share on other sites More sharing options...
Blake Posted October 19, 2012 Author Report Share Posted October 19, 2012 Awesome thanks, you get yours? you like? Quote Link to comment Share on other sites More sharing options...
trials hoe Posted October 19, 2012 Report Share Posted October 19, 2012 yea mate, took me ages go and get it from the abyss that is the sorting office haha think i may raw it..... along with everything else haha Quote Link to comment Share on other sites More sharing options...
Blake Posted October 19, 2012 Author Report Share Posted October 19, 2012 yea mate, took me ages go and get it from the abyss that is the sorting office haha think i may raw it..... along with everything else haha yeah i'd raw it, polish it or sand it with a high grade sandpaper as I did it with some really rough stuff and it has a scratched/ghetto look to it. Quote Link to comment Share on other sites More sharing options...
dave33 Posted October 19, 2012 Report Share Posted October 19, 2012 (edited) Ha yeah I did try that. I think Chris King only make certain hubs with that non-uniform shimano pattern. Can anyone confirm this? Edit: My hub has a totally uniform pattern, but the Gusset double six I got from crc didn't. Ha yeah I did try that. I think Chris King only make certain hubs with that non-uniform shimano pattern. Can anyone confirm this? Edit: My hub has a totally uniform pattern, but the Gusset double six I got from crc didn't. They will fit the iso/classic etc as they are all shimano or campag (won't fit campag) sounds like you have a single speed king hub which is uniform Edited October 19, 2012 by dave33 Quote Link to comment Share on other sites More sharing options...
