My Gu Typhoon Build Thread (2007 Frame)
Blake
Right, finally got enough pictures of my new bike to start taking pictures of it and putting it on trials forum, I will update this as it goes along.
ooh baby.
So that's it how it currently stands, got a few more bits I want to get, here is the current spec list:
Bars: Trialtech Sport
Stem: Trialtech Forged
Headset: FSA orbit equipe
Forks: Breath 4-bolt
Frame: GU typhoon 07
Bottom bracket: V!Z
Cranks: Trialtech ISIS 170's
Rear Hub: Chris king classic
Rim: Echo urban (36h, 47mm)
Brakes: Front, blue 04 maggie with heatsink yellows (plastic)
Back, blue 04 maggie with black slaves with heatsink yellows (metal backed)
Got front wheel, tyres and sprockets to come along yet, as well as a new chain, but most of these are sorted. Will be changing to echo urbans up front, with a front V, but will edit this post when it all comes together :)
That's it for now, stay tuned and let me know what you think!
  • Like 1
UPDATE!
Finished the build, got some urbans to pop on the front then it will be as it is for a while :)
Pictures:
Really happy with how it rides! will be a bit nicer with the front V I have on the way though.
Spec is:
GU typhoon 2007 Frame
Breath 4-bolt forks
FSA Orbit Equipe headset
Trialtech high rise stem
Trialtech Sport bars
Trialtech foam grips
Onza hog front rim on a sealed v!z hub
Echo urban rear rim on a chris king classic
V!Z ISIS bottom bracket
Trialtech ISIS 170mm cranks
DMR V8 pedals.
18T trialtech lite (might be sport) sprocket
15T DoubleSix sprocket on the back
Trialtech sport tensioner
KMC z510HX chain
Back brake is a 2004 blue magura with black slaves and CNC heatsink yellows with a echo urban 2 bolt booster. Tensile offset mounts.
Front brake is currently a 2004 blue magura with blue slaves and plastic backed heatsink yellows.
Think that's everything :) Video up shortly!
  • Like 1
Luuuurrrvveeeee it, can't wait to have a do at 'dem to fronts'! Is that my cross over you are using on the rear? If so, I made that especially for you :3
no me and ant made a new one, yours leaked due to lack of threads :P Thanks anyway though x
Goes to front like an angel.
90*HA, -50bb and 3000wb? Sweeeeet!
tgs riders dream mate :P
guess breath forks are one to avoid then.........
did you escape without injury?
they were cracked but yeah i'd steer clear of them anyway.
Yeah the went dropping off a bench, I noticed my brake was rubbing and when I looked at my forks I realised the forks had a monster crack on them, then on the way home I was smacking the front wheel on the ground and it just gradually bent all the way round :P then I put the down and they looked like that, then the snapped picking up the bike!
Did do a lot of up to fronts/gap to fronts on them though, and I am a bit of a basher!
