Helicoils
the mysterious leemur
Right so guys I've stripped a few of the bolts on my echo from a combinatioof me being stupid and a dodgy clamp set up. A couple have no thread and the bolt rattles around inside.
I'm planning on helicoiling it but I don't really know how other than the basic steps, what sort of lengths and things am I needing to know ( other than m5x0.8 ). A link to a supplier would be great too
Edited by the mysterious leemur
I picked up a Clarkes M5X0.8 Kit off ebay for about £12.
Its been invalueable in sorting me out.
supplied with a drill bit, tap, tool to wind in the helicoil itself, and a punch to break the tab on the coil once its wound in.
Think it comes with roughly 15-20 helicoils too. Not shoddy quality either. Fixed my frame, forks and other frames for them and non have pulled out/stripped.
Just make sure you use the tap by hand, and go slow. Get it started, and then after every turn, go back another turn and a half to chase the threads and make sure its a clean tap.
Its dead easy once you get the hang of it.
  • 10 months later...
Monster thread bump
http://www.timesert.com/
I had the pleasure of a demo from the wurth guy last week. While his back was turned i got a 2' cracker bar on an m6 and managed to shear the head off the bolt, helicoil just became obsolete imo
Edited by f**megently
  On 9/18/2013 at 12:13 AM, f**megently said:
Monster thread bump
Been talking about these for years, what I use in work, Helicoils are good for some purposes just not most of what's required on a bike component
  On 9/18/2013 at 12:54 PM, dann2707 said:
Or install the helicopter properly in the first place and never have any trouble anyway? Thought you were an engineer...
Haha helicopter. Love autocorrect
So far iv never seen a failed timcert but iv lost count of f**ked Helicoils if seen when people have brought me some thing to be repaired which they have tried to Helicoil in the past. Like I said not the correct application from them.
You Perfectly entitled to you own opinions on them. You carry on.
