Using A Smaller Disc Rotor?
Jolfa
That's not moving the calliper closer though. If anything isn't that moving it further away....
Also if you move the calliper down as opposed to rotate it around the axle (or alternatively bring it in relative to the axle) the disc won't pass through correctly. The whole pad wouldn't touch the disc as only a percentage or angle of the disc would rotate through the newly positioned calliper.
Edited by Matthew62
The drawing, as intricate as it may be, may not be quite to scale.
Moving the caliper down and angling the adaptor slightly to compensate for rotation as you say, would solve the problem.
I'd take a picture of this with the caliper on the forks where it would need to be mounted to make up the difference, but I cannot be arsed :)
But as you can see, nothing about this idea is absurd in the slightest.
