Disc Brake Reviews
Nigel Kilgar
when looking through this forum i've noticed theres not many disc brake reviews like there are maggy and pad reviews so i thought id start one
main things are:
make:
model:
bike used on:
pads used:
rotor used
rotor size:
front rear or both:
good points:
bad points:
ill start
make:avid
model:elixir 5
bike used on: 2012 inspired fourplay
pads used:avid organic
rotor used: avid clean sweep 3
rotor size:203
front rear or both:both
good points: the only good point i can find with them is there cheap and good for beginners
bad points: i got my brakes brand new on my 2012 inspired fourplay and all seemed good till they just have no bite or hold even with 203 rotors i ended up on my arse a few times when they slipped and then the rear lever popped and i sent it back to avid received it back and it still feels spongey and does not hold or bite
conclusion: will not be buying a set again or running them on a trials bike as i value my life
make:magura
model:mt2
pads used:oem
rotor used shimano xtr ice tech
rotor size:180
good points: cheap, light, easy to shorten hose and bleed front brake is great doesn't rub and bites and holds ok for now still bedding in
bad points: rear brake rubs constantly on the rotor and seems to knock when gapping tried re setting the caliper everything no luck and everythings tight and no bite adjustment
conclusion: going to give them a week if they don't improve i shall be selling them and buying echo tr discs as i know they work
post your situations below
  • Like 1
good point nige. any chance of getting this made into a sticky Tom? or Dave?
make: echo
model: tr
pads: standard echo, red backed
rotor: echo
bike used on: onza blade with echo urban forks
rotor size: 180mm
good points: very good lever feel, massive bite and power. lever reach and bite point adjustable.
bad points: lever is weeping a bit, and it takes a lot of bedding in in the right way or you get no bite and hold.
conclusion: very good brake for the money, deffo have one over a mono trial any day of the week. the only brake I would change this for is a saint. no other
Make: Shimano
Model: Saints m810
Bike used on: Because color 20"
Pads used: Original ones.
Rotor used: Shimano acera :$
Rotor size: 160mm
Front rear or both: Rear.
Good points: Amaaaaazing bite and hold, way better than Magura. Lever both looks and feels amazing too. The gold reach adjust is cool. Yeah just generally a awesome brake that spanks the shit out of Hope!
Bad points: Sometimes have too much power, so the tyre almost makes a little 'skid' when you're doing a wheelie or just pedaling up to the rear wheel hard. Modulation is ok, but I don't need it. Yeah just sometimes have to much power, but I love it! A bad point is that it's soundless, I wan't a brake that scares the shit out of people;) Might be a bit expensive.
Buy it if you can, you won't regret it! (Y)
make: Avid
model: BB7
bike used on: 20"s, 24"s 26"s, front + rear on all
pads used: standard avid
rotor used: standard avid roundagon
rotor size: 160/185/203mm respectively
front rear or both: both
good points: cheap to keep, excellent hold, no feeling of bite, but the power is always there. can provide modulation alongside serious power. massive adjust-ability, coupled with sd7 levers you have alot of variables to play with... easy to install/set up
bad points: kinda heavy, but it's not super heavy, the performance and toughness are worth it.
make: Hope
model: Tech Trial with the fancy lever
bike used on: echo 20"
pads used: hope ones
rotor used: generic one
rotor size: 180
front rear or both: front
good points: awesome power and bite, light, can tune the lever position. feels ace
bad points: the lever blade itself has eaten my fingers this week. got a nice blister on my finer and cuts on my knuckles from the blades sharp edges :(
also:
hydraulics always make me a little wary cause failure means expense + fannying about, a broken cable brake, you can always get spares...
