trialsiain Posted October 2, 2012 Report Share Posted October 2, 2012 came back from comp in scotland on sunday and bike was completly covered in mud i left it overnight and washed next day but all the bolts on magura clamps have rust in the hole of them and the pedals too, should i spray gt85 on ? also what do i put in freewheel to stop it happening to it ? Thanks Quote Link to comment Share on other sites More sharing options...
Aidan97 Posted October 2, 2012 Report Share Posted October 2, 2012 I put a bit of oil in but it doesn't make much difference in my opinion, and your freewheel should be fine unless you've degreased it but you could just clean the inside and put some fresh grease on it if it ended up dirty Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted October 2, 2012 Report Share Posted October 2, 2012 I put a bit of oil in but it doesn't make much difference in my opinion, and your freewheel should be fine unless you've degreased it but you could just clean the inside and put some fresh grease on it if it ended up dirty No need to put grease in the freewheel,just spray some gt85 in it an you should be fine. Quote Link to comment Share on other sites More sharing options...
weegav Posted October 2, 2012 Report Share Posted October 2, 2012 I cant get the mud off my forks i sprayed wd40 on my magura bolts and stem bolts Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted October 2, 2012 Report Share Posted October 2, 2012 I cant get the mud off my forks i sprayed wd40 on my magura bolts and stem bolts Are you sure it´s mud? 1 Quote Link to comment Share on other sites More sharing options...
weegav Posted October 2, 2012 Report Share Posted October 2, 2012 its really thick mud. will need to power wash them Quote Link to comment Share on other sites More sharing options...
Blake Posted October 2, 2012 Report Share Posted October 2, 2012 mucoff/nomoredirtybike? Quote Link to comment Share on other sites More sharing options...
JD™ Posted October 2, 2012 Report Share Posted October 2, 2012 Have you tried washing it? Y'know, like with a soap and water which is warmer than cold? Quote Link to comment Share on other sites More sharing options...
weegav Posted October 2, 2012 Report Share Posted October 2, 2012 yeah i have used hot soapy water Quote Link to comment Share on other sites More sharing options...
JD™ Posted October 2, 2012 Report Share Posted October 2, 2012 Have you tried some elbow grease? Quote Link to comment Share on other sites More sharing options...
weegav Posted October 2, 2012 Report Share Posted October 2, 2012 il try jet washing it tomorrow that should get rid od it Quote Link to comment Share on other sites More sharing options...
gnarled Posted October 3, 2012 Report Share Posted October 3, 2012 Have you tried some elbow grease? Quote Link to comment Share on other sites More sharing options...
