Ash-Kennard Posted September 27, 2012 Report Share Posted September 27, 2012 if the diamonds were to become squares, will the rim last and how much weight could be saved? everything i buy atm seems to be light, so i may aswell get on with it properly 1 Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 27, 2012 Report Share Posted September 27, 2012 So long as you added a small radius to the corners of the sqaures, it should be okay. 1 Quote Link to comment Share on other sites More sharing options...
dave33 Posted September 28, 2012 Report Share Posted September 28, 2012 Depends on tyre pressure. If your running low pressure less than 17/19psi where you rim out a fair bit you will flat spot the rim easy. But normal pressure it should be plenty strong enought Save about 30 grams probly Quote Link to comment Share on other sites More sharing options...
ogre Posted September 28, 2012 Report Share Posted September 28, 2012 drill them sidewalls too! Quote Link to comment Share on other sites More sharing options...
Al_Fel Posted September 28, 2012 Report Share Posted September 28, 2012 No one on here can give you an honest answer unless they have done it themselves. I personally wouldn't bother. It will take ages to do and you wont notice any difference at all. If you want to do it then A) Get a life and Just do it! Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted September 29, 2012 Author Report Share Posted September 29, 2012 fair enough, might just wait for the sky rim again then Quote Link to comment Share on other sites More sharing options...
315r Posted September 29, 2012 Report Share Posted September 29, 2012 Talking about onza diamond let me ask another question. Do you use this with HS? It hold a grind well? Quote Link to comment Share on other sites More sharing options...
the mysterious leemur Posted September 29, 2012 Report Share Posted September 29, 2012 They like every onza rim I've encountered cant hold a grind for more than a few days and have very temperamental performance 1 Quote Link to comment Share on other sites More sharing options...
