Freewheel Problem
trialsiain
if your chain gets tight loose tight loose tight loose then your freewheel or sprocket is bent slightly...
mine done that and when i changed it the chain slack was the same all round :)
No it doesn't.
It's perfectly normal for some side to side movement,
It's nothing to worry about.
