Kevinfor Posted September 24, 2012 Report Share Posted September 24, 2012 Hello everyone. I was thinking of getting a front rim brake setup and i noticed the urbans have the mounts on the front of the legs and the trialtech ones are mounted on the back. Is there any pros or cons to either one? Thanks a lot. Kevin. Quote Link to comment Share on other sites More sharing options...
isitafox Posted September 24, 2012 Report Share Posted September 24, 2012 Yup, when you apply the brake the wheel is effectively pushing or pulling on the brakes. With them mounted on the rear they push into the forks giving more resistance which technically should make them more effective at the risk of increasing the stress put into the forks which causes them to snap. Quote Link to comment Share on other sites More sharing options...
trials hoe Posted September 24, 2012 Report Share Posted September 24, 2012 brakes will work the same either side of the fork legs, same fittings and way they mount et all. would have thought reverse mount would be more resistant to cracking at the mounts with moves to front.......... Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted September 24, 2012 Report Share Posted September 24, 2012 yup. but the likely hood of someone breaking urbans is very small. Quote Link to comment Share on other sites More sharing options...
Blake Posted September 24, 2012 Report Share Posted September 24, 2012 yup. but the likely hood of someone breaking urbans is very small. Really? i'd say urbans are pretty easy to snap. . . Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 24, 2012 Report Share Posted September 24, 2012 yup. but the likely hood of someone breaking urbans is very small. Ross C managed to crack his forward facing urbans in just shy of 4 months I think. Him and Ben L used to go through a good amount of them too. Quote Link to comment Share on other sites More sharing options...
Blake Posted September 24, 2012 Report Share Posted September 24, 2012 But reverse mounts for the win, look and (supposedly) work better. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 24, 2012 Report Share Posted September 24, 2012 (edited) They both have there pros and cons. Reverse: Pros; Generally better bite and hold, down to the way the pads are forced inwards with the rotation of the wheel. Look awesome. Cons: Will tend to crack/ snap easier on moves such as hooks or wodges. The mount adds as a stress riser, and with the way the fork flexes on such moves, this causes the fork to crack Forward mount: Pros: Generally quite quiet, tad more modulation (if you like that kinda thing) and more resistant to hook/wodge induced cracks Cons: Can have less hold than a reverse mount vee, the key word being CAN. (Mr. Pavel has proved you can get an epic front brake with such mounts) and will be more prone to cracking at the mount with moves to front. In short, theyre both going to crack sooner or later, and you should get a good brake on either. Ive gone front Vee though, so Im a winner anyway. Hooray for strong forks. Edited September 24, 2012 by Echo Lite 09 Quote Link to comment Share on other sites More sharing options...
dave33 Posted September 25, 2012 Report Share Posted September 25, 2012 Really? i'd say urbans are pretty easy to snap. . . Ye I had some before when trial tech were out of stock. Brakes shit and they lasted 2 months if that Trialtech last me 3/5 months and brakes alot better Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted September 25, 2012 Report Share Posted September 25, 2012 Trialtech seem pretty reasonable with rearward facing HS mounts. My Viz front facing only last about 9 months Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted September 25, 2012 Report Share Posted September 25, 2012 Rear facing - WIN Front facing - SHIT Quote Link to comment Share on other sites More sharing options...
Trials-Mikey Posted September 25, 2012 Report Share Posted September 25, 2012 yup. but the likely hood of someone breaking urbans is very small. i broke urbans in two months they were fitted correctly and the snapped at the crown race swapped to trialtech sport forks and they are more stronger and both the forks had reverce fittings Quote Link to comment Share on other sites More sharing options...
