tpickup Posted September 19, 2012 Report Share Posted September 19, 2012 snapped chain learning pedal kicks, then had realisation if that happened when you were a considerable amount away from the ground up on and obstacle you would be screwed. wondered if any body has had the bad experience of that happen to them. Quote Link to comment Share on other sites More sharing options...
ChrisTrials2012 Posted September 19, 2012 Report Share Posted September 19, 2012 Oh dear God.................................................................................................... Quote Link to comment Share on other sites More sharing options...
Blake Posted September 19, 2012 Report Share Posted September 19, 2012 yeah it happens, some people get hurt some don't. let me find some clips Quote Link to comment Share on other sites More sharing options...
trialsiain Posted September 19, 2012 Report Share Posted September 19, 2012 What kind of chain was it ? And we're you using split link Quote Link to comment Share on other sites More sharing options...
tpickup Posted September 19, 2012 Author Report Share Posted September 19, 2012 unsure and dont think it was split linked, the chain can be replaed i was aiming for more storys about same happening to others but it more dangerous situations Quote Link to comment Share on other sites More sharing options...
Jake. Posted September 20, 2012 Report Share Posted September 20, 2012 By the time you get good enough to do drop-gaps or big drops I'm sure you'll know your trials bike well, what issues to look for to minimize risk. I saw a video once of a guy going for a gap, chain snapped and he faceplanted. Think he was on a GU stock? Quote Link to comment Share on other sites More sharing options...
CalopS Posted September 20, 2012 Report Share Posted September 20, 2012 They keep showing it on you've been framed! Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted September 20, 2012 Report Share Posted September 20, 2012 I got set a line over some rocks which were placed in a pond (although at this point it were more like a swamp -.-) anyway I had to skip out the middle rock each time... got over the first one, preloaded on the second, gave an explosive kick, then I was looking at the sky hearing a little bit of laughter, looked in the distance and there was my chain, it had flown over my head and travelled through the air. A pic of me after the tragic incident Quote Link to comment Share on other sites More sharing options...
mike Posted September 20, 2012 Report Share Posted September 20, 2012 your chain is on your bike in the pic 2 Quote Link to comment Share on other sites More sharing options...
Danny00135 Posted September 20, 2012 Report Share Posted September 20, 2012 your chain is on your bike in the pic bodged a fix... Quote Link to comment Share on other sites More sharing options...
VAMPIRE V12 Posted September 20, 2012 Report Share Posted September 20, 2012 get a kmc 910 should not have any problems with chain snaps haha the worst chain snap for me was when i was riding normally not really doing anything just picking up some speed and i went down like a sack of S**T 1 Quote Link to comment Share on other sites More sharing options...
bing Posted September 20, 2012 Report Share Posted September 20, 2012 I snapped mine on my old inspired trying to do a fakie down the local skatepark. had a right gash on my elbow where I went crashing to the ground like I'd been shot. that was a renolds 3/16ths machine chain as well Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 20, 2012 Report Share Posted September 20, 2012 Done this on a dropgap, just let go of the bars and rolled out of it. May not be possible in every situation however. Always pays to check your chain over pre ride Quote Link to comment Share on other sites More sharing options...
shercofray Posted September 20, 2012 Report Share Posted September 20, 2012 Did this a while ago: Not fun. 1 Quote Link to comment Share on other sites More sharing options...
Mtchell Posted September 23, 2012 Report Share Posted September 23, 2012 I like to change a chain every 2-3 month depending on the amount of riding, I had a snapper in hull on a drop , my right knee took a smashing on the stem....your knees are worth 30 bob every few month Quote Link to comment Share on other sites More sharing options...
dezmtber Posted September 23, 2012 Report Share Posted September 23, 2012 i use the kmc kool chains curently been using a k710sl for 6 months with the split link and it still feels and looks spot on. a bit of advise when buying your chains take a good look at how the pins have been riveted to stop the outer plates spliting the k710sl chain is riveted all round the pin as the pins are hollow. cheap chains has a cross rivet which can be in some cases weaker and more likely to split. . when i used cheaper chains years ago i rearely snaped chains on the link without signs of a failed pin and if they did snap it was usualy at the piont where the kmc k710 is beefed up to not snap. Quote Link to comment Share on other sites More sharing options...
Ben Gosden Posted September 23, 2012 Report Share Posted September 23, 2012 Danger is part of riding you gotta expect some painfull times but you could try out some beefed chains especially designed to be stronger than the others and also keep an eye on your sprocket becouse unlike alot of people think they wear down which then wears your chain down at twice the speed. Also a nice healthily lubed chain with help it live a longer life. Quote Link to comment Share on other sites More sharing options...
pete trials Posted September 23, 2012 Report Share Posted September 23, 2012 3 Quote Link to comment Share on other sites More sharing options...
Ben Gosden Posted September 23, 2012 Report Share Posted September 23, 2012 Ouch, ouch and OUCH again !!! Quote Link to comment Share on other sites More sharing options...
