VAMPIRE V12 Posted September 11, 2012 Report Share Posted September 11, 2012 Heyy guys. Went out tonight on my onza zoot and pulled the thread out of my chain tensioner on the non drive side, i have switched the tensioners over and screwed the thread back in and it seems to be holding for now. But does anyone know of any really big beefy chain tugs to help stop this happening again? My hub is a Hope pro 2 sst Cheers guys Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 11, 2012 Report Share Posted September 11, 2012 Gusset do some pretty meaty ones. Tarty sold them, probably still do. Been a while since I looked. Would link you but im on my phone, which makes it a pain in the arse. Quote Link to comment Share on other sites More sharing options...
VAMPIRE V12 Posted September 11, 2012 Author Report Share Posted September 11, 2012 my internet was loading up spotted them now mate the gusset kojak ones. Cheers mate! 1 Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted September 11, 2012 Report Share Posted September 11, 2012 Can you not just use a nut that fits the the drop out effectively slamming the wheel and then using a spoke tensioner to take up the extra slack? Quote Link to comment Share on other sites More sharing options...
Blake Posted September 11, 2012 Report Share Posted September 11, 2012 gusset are the shit Quote Link to comment Share on other sites More sharing options...
VAMPIRE V12 Posted September 12, 2012 Author Report Share Posted September 12, 2012 Heyy guys i'm having problems keeping my wheel in place as you can see the hopes bolt grips on to the chain tugs that hold into the frame but the chain tugs are just smooth so they can move about but i do not want to put too much power on to try. When i put them behind the frame it pushes my caliper so far off it bends the disc, has anyone else had such a problem or know how to fix this? Cheers guys Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted September 12, 2012 Report Share Posted September 12, 2012 try puttin some sort of rubber washer between the bolt and chain tug. Quote Link to comment Share on other sites More sharing options...
CalRobbo341 Posted September 12, 2012 Report Share Posted September 12, 2012 Is it possible to munt a diffrent sort of tensioning device? Sprung one or even a spoke tensioner if you get a new chain? Onza normally do something diffrent so it may be worth a try? Quote Link to comment Share on other sites More sharing options...
VAMPIRE V12 Posted September 12, 2012 Author Report Share Posted September 12, 2012 There is no holes for any tensioners :/ and brad ill have a go at that and ill pop over to yours sometime possibly help me bodge something Quote Link to comment Share on other sites More sharing options...
VAMPIRE V12 Posted September 14, 2012 Author Report Share Posted September 14, 2012 My kojak chain tugs came in the post yesterday and i must say quite a big improvment to what i originally ran, cheers guys Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 14, 2012 Report Share Posted September 14, 2012 The tugs are more of an aid to setting it up rather than the thing that holds them in place. If you grease up your axle bolts on your Hope, you should be able to tighten them up quite a bit without any problems, and they'll hold your wheel in place fine. Quote Link to comment Share on other sites More sharing options...
