Stan Titanium
Mark W
Stan Titanium is a new brand to the UK, specialising in lightweight ti upgrade bolts and fittings.
They manufacture the usual range of M5/M6 bolts:
However, they also make barbed fittings/shroud nuts for Magura (and some Echo) brakes:
They also supply HS33 lever pivot bolts for '04/'05 levers:
As well as lever pivot bolts for the Hope Mini lever:
For people running V-Brakes they make two sizes of V-Brake Studs:
As well as other items such as pedal cage bolts and pedal axles (for Wellgo MG-1 based pedals, Echo TR Caged pedals and Try-All Superlight pedals):
Rotor bolts:
And finishing kit such as a range of sizes of headset spacer and some pretty sweet M15 ISIS crank bolts:
  • Like 1
Noice! Would be interesting to see a bike with normal steel bolts and weigh it then do an after with stan bolts etc. Just to see if there is a difference in weight.
Id need a mortgage to afford a full ti set :/
Edited by Andeee
