Martin Reynolds Posted September 6, 2012 Report Share Posted September 6, 2012 I've got a stock hope pro 2 disk hub laced 3x to a onza rim (the one with the onza hogs stamped out of them and drilled sidewalls). I want to lace it onto a Onza sealed bearing non disk hub (http://www.tartybikes.co.uk/front_non_disc_hubs/onza_sealed_non_disc_front/c86p224.html). I know the hubs have different flange sizes, i was wondering could i get away with using the original spokes, just lacing it 2x/1x? I know this could properly be figured out with a spoke calculator, but that confuses the hell out of me Cheers Quote Link to comment Share on other sites More sharing options...
Mikee Posted September 7, 2012 Report Share Posted September 7, 2012 New spokes Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted September 7, 2012 Author Report Share Posted September 7, 2012 New spokes Wanna explain why? Will using a straighter lacing pattern not give me the extra length needed for smaller and wider flanges? Quote Link to comment Share on other sites More sharing options...
ooo Posted September 7, 2012 Report Share Posted September 7, 2012 Pro 2 Front QR 100 Onza Hub Dia Left 56 38 Dia Right 54 38 Centre to Left 19.5 34 Centre to right 34 34 Spoke Hole 2.6 http://www.hopetech.com/webtop/modules/_repository/documents/OldHubDimensions.pdf Yes hubs are very different sizes use this calc I think its pretty easy... http://lenni.info/edd/ (Press the small enter your own measurements button) All you need is the ERD of your rim. If you wanna change lacing still calculate it, you only get +/- 2mm of tolerance, even then its annoying, spot on spokes are worth it, halo spokes are cheap and do the job. itll only be about £7.50 for them Quote Link to comment Share on other sites More sharing options...
