Wheeler Posted September 1, 2012 Report Share Posted September 1, 2012 Hi there I have heard about putting water in brakes and that it works really well for trials, but I can only seem to find people doing it with maguras. Does anyone know if it will be ok in hope mini brakes? Cheers Ian Quote Link to comment Share on other sites More sharing options...
onza pro series guy Posted September 1, 2012 Report Share Posted September 1, 2012 No!!! It will boil the water and leak form the seals as most disc brakes run DOT fluid Quote Link to comment Share on other sites More sharing options...
trials hoe Posted September 1, 2012 Report Share Posted September 1, 2012 i had a water bled mini mono caliper and that was fine ( i did fit new seals) dunno how the lever will fare with water in it though, i was running it on a maggie lever. Quote Link to comment Share on other sites More sharing options...
Jake. Posted September 1, 2012 Report Share Posted September 1, 2012 Don't do it haha, discs heat up way easier than maguras. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted September 1, 2012 Report Share Posted September 1, 2012 Stick it on the rear brake and use the front to slow down, only using the rear for on/off trials moves you won't boil it. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted September 1, 2012 Report Share Posted September 1, 2012 Just remember to tell people if you let them have a go on your bike. Nightmare!! Quote Link to comment Share on other sites More sharing options...
williams Posted September 1, 2012 Report Share Posted September 1, 2012 it's possible to do, but I would highly avoid you from doing it. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 1, 2012 Report Share Posted September 1, 2012 If you value your brake, no. Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted September 1, 2012 Report Share Posted September 1, 2012 Just use dot it is just as thin as water and wont kill your brakes. People only use water as it is thinner than mineral oil therefore being a nicer feeling at the lever but this doesn't apply as Dot will give the same feeling due to it being very thin. Quote Link to comment Share on other sites More sharing options...
Wheeler Posted September 1, 2012 Author Report Share Posted September 1, 2012 Ok cheers for the replys I'll prob just stick with oil I think, it sound good but could be a nightmare Quote Link to comment Share on other sites More sharing options...
Revolver Posted September 2, 2012 Report Share Posted September 2, 2012 Get hold of some DOT3, a google search tells it'a compatible and should be thinner. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted September 2, 2012 Report Share Posted September 2, 2012 I thought Dot5.1 is thinner than Dot4 which, if following a pattern would make Dot3 thicker? Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted September 2, 2012 Report Share Posted September 2, 2012 you will also need to flush the system out if you change the fluid as 2 types cannot mix. Quote Link to comment Share on other sites More sharing options...
dave33 Posted September 4, 2012 Report Share Posted September 4, 2012 It's wont boil, not at trials speeds! You can buy seals for mineral fluid for them, otherwise it will be ok for a couple of months until the seals swell Quote Link to comment Share on other sites More sharing options...
