SamKidney Posted August 30, 2012 Report Share Posted August 30, 2012 (edited) Having a little issue with my chain length on my 24", Im thinking its my tyre thats the problem. In order to run my wheel without the tyre catching the end of the top tube, I have to run one half link. No problem I thought, I'll wait until the chain stretches a little. I hate running half links, make a little bit of paranoia kick in, and when I went to try remove it, the tyre is still hitting the top tube with the chain set how its meant to be. Has anyone else had this issue with their Fat Albert and chain length? Im thinking maybe its because it is a very large tyre, and I'll have to wait until the tread wears a tad before it stops catching. Im running 18-14 gearing, I assume thats standard? Edited August 30, 2012 by Echo Lite 09 Quote Link to comment Share on other sites More sharing options...
CalopS Posted August 30, 2012 Report Share Posted August 30, 2012 cut down the tread a bit? Quote Link to comment Share on other sites More sharing options...
aener Posted August 30, 2012 Report Share Posted August 30, 2012 (edited) You've hardly been riding it long... [Edit: New] chains stretch pretty quick, but not that quick. To be brutally honest, as inadvisable as half-links are, people do make them out to be worse than they really should. You'll be fine running it until the chain stretches enough. If it's that far down, can you not put the extra link in? (Take half link out and add a full link.) Edited August 30, 2012 by aener Quote Link to comment Share on other sites More sharing options...
SamKidney Posted August 30, 2012 Author Report Share Posted August 30, 2012 With the half link the hub is the furthest out in the dropout it can be ran. I suppose I'll just run it. Quote Link to comment Share on other sites More sharing options...
Jake. Posted August 30, 2012 Report Share Posted August 30, 2012 18-14 is fine. My tyre rubs sometimes, just let it down a little bit that helps for me. Last resort is to cut the 'tail' that it rubs onto, off. Quote Link to comment Share on other sites More sharing options...
narrowbars Posted August 30, 2012 Report Share Posted August 30, 2012 For the three ride's I used that tyre I didn't need a half link and no rubbing issues? Once your chain stretches a bit you'll be fine Quote Link to comment Share on other sites More sharing options...
SamKidney Posted August 30, 2012 Author Report Share Posted August 30, 2012 Dont fancy cutting my frame Like I said, I'll run it with the half link for now until it stretches. Quote Link to comment Share on other sites More sharing options...
Jake. Posted August 30, 2012 Report Share Posted August 30, 2012 Leave it as it is then case solved. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted August 30, 2012 Author Report Share Posted August 30, 2012 Just wanted to see if there were any other suggestions Cheers guys. 1 Quote Link to comment Share on other sites More sharing options...
Azarathal Posted August 30, 2012 Report Share Posted August 30, 2012 With my wheel slammed in the dropouts (spoke tensioner) I have enough clearance for my fat albert and a vee, is your tyre seated properly? Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 1, 2012 Author Report Share Posted September 1, 2012 (edited) Definately seated properly. Are Schwalbe tyres hand made like Contis? Maybe mines a tad larger than stated. Im running a V!Z rim if that makes a difference? Being wider than a TR.. Edited September 1, 2012 by Echo Lite 09 Quote Link to comment Share on other sites More sharing options...
Azarathal Posted September 1, 2012 Report Share Posted September 1, 2012 Being wider might have something to do with it but mines a good inch at least away. Try a spoke tensioner? Position it so it doesn't rub and you can set the brakes up then use a spoke to tension. I've done it because I cba getting the tensioners even or adjusting it as the chain wears Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 1, 2012 Author Report Share Posted September 1, 2012 An inch! Mines running on the end of the dropouts and Ive got half an inch, if that. Sounds like my tyre is Mahooosive compared to others. All the factors are pointing to the tyre at the minute. Wheel all the way back, brake clamps the same.. Just going to get a high roller on there soon. Quote Link to comment Share on other sites More sharing options...
trialsiain Posted September 1, 2012 Report Share Posted September 1, 2012 mine has no half link and i have big betty which is bigger and its about 2mm away from the pointy bit and its a new chain. Quote Link to comment Share on other sites More sharing options...
